For sale pcb Fortuna M2/M3 and M3
  • Ahmetnarci
    [QUOTE=blobber;n428381]https://mplab-ide.software.informer.com/8.91/ Загрузите и установите этот инструмент на свой компьютер. Затем следуйте инструкциям в видео.
    [/ЦИТИРОВАТЬ]
    Thank you very much, I will try again, hopefully it will work this time.
  • blobber
    Download and install this tool on your computer. Than follow the instructions in the video.
  • blobber
    Originally posted by Ahmetnarci View Post
    Is there anyone who can help with your issue?
    Here in the video, you can see how to flash the hex file.
  • Carl-NC
    "but when I select the load hex option..."
    I don't know what this means. You should be able to simply click the Run or Program button.
  • kt315
    you have to go into russian forum and ask. i give a link MD "Fortune_M" - Просмотр темы • Схемы металлоискателей MD4U •​
  • Ahmetnarci
  • Ahmetnarci
    Good night everyone, my problem with fortune m3 is this: I create a project by selecting the embedded system and the previously created hex file from the new project option with mplab x ide. Up to this point, everything is normal, but when I select the load hex option, a message appears saying that the load was not attempted because the mplab memory is empty. What is the problem? I need your urgent help. Thank you very much to everyone in advance
  • Carl-NC
    Please post in English, thanks.
  • Ahmetnarci
    Gute Nacht alleseits, mein Problem mit Fortune M3 ist, dass ich das Projekt erstelle, indem ich das eingebettete System und die zuvor erstellte Hex-Datei aus der neuen Projektoption mit MPlab auswähle. Ich brauche dringend Ihre Hilfe, vielen Dank im ​​
    Good night everyone, my problem with fortune m3 is this: I create a project by selecting the embedded system and the previously created hex file from the new project option with mplab x ide. Up to this point, everything is normal, but when I select the load hex option, a message appears saying that the load was not attempted because the mplab memory is empty. What is the problem? I need your urgent help. Thank you very much to everyone in advance.
  • blobber
    Well, I have just one last bare pcb, which is waiting to pick up all components. I do not order another pcb bundle, because now I've other preferences for vlf detectors. But anyway, Fortune is worth to build.
  • Sando_ pretorii
    are there any more?
  • Suvabard
    A very very belated update (due to some real world complications that took me away from the hobby). Using your post I was able to get it working perfectly. Thank you once again, you've been a real help!
    Originally posted by Suvabard View Post
    Hi Fred,
    Thanks so much for putting this post together . I'll have a chance to go through the procedure later next week and will post the results to the thread.
    Suvabard
  • blobber
    Some pictures as well..
  • blobber
    Again after a while with doing other things, a pcb is completed.
  • blobber
    Hi Fred,
    Suvabard
    You're welcome.
