Detector rod and electronic housing assembly
  • Detector rod and electronic housing assembly
    Have about 100 complete new S rods with foam grips, armcups, detector stands, lower rods, locking compression nuts, hard plastic electronic housing (4 inch wide X 5 3/4 inch deep X 2 inch thick) to house your own circuit board, with battery compartment, battery door with latches and a metal front bezel to mount your controls and speaker on. It has all the hardware for you to put your own circuit board and coil in if you want to build your own metal detector or modify what you already have. All of it is new, no used parts. These are the same housings and pole assemblies of the older Gold Mountain King Cobra model detectors. Just have too many of them and will sell them for $20.00 ea. and shipping of $11.00 to you. Total $31.00 and this is a great deal! Contact me for photo:
    [email protected]
    [email protected]
    Pic.. Please!! Also, what are the dimensions for the lower rod clevis diameter?
    Thanks..
    Don
      Thanks..
      Don
      And material of lower rod too?
        Of course we ALL want to see pictures
          Detector Rod and Electronic Housing....
          The lower rod is made of thick white color fiberglass I think, it will not flex when you swing the unit, it is heavy duty but not heavy in weight. The clevis is the orginal Gold Mountian type clevis glued on the end of the rod with a narrow width of 1/4 inch wide with 1/4 inch bolt hole. Several also have the orginal Whites type of clevis 3/4 inch wide with two rubber washers and 1/8 inch coil bolt hole like the older Whites rods.
          Sorry, but haven't learn how to attach photos to this post yet, but have email several folks photos of them already that email me. Keith
          [email protected]
            [email protected]
            When you click on Post Reply, scroll down the page until you see a button labelled "Manage Attachments". Use this feature to post images in the forum. In particular, note the restrictions on file type and file size. You can use image processing software, such as GIMP, to reduce any oversize images. In some cases it may be also advisable to compress the files to either zip or rar formats.
              Maybe this will help
              From the King Cobra flyer
                King Cobra PCB dimensions are:
                - width 91,4 mm
                - length 122,7 mm
                  [email protected]
                  Yes, we need these. Please post pics!!
                    Unfortunately he won't send them outside of the US, a shame I would have had a couple!
                      I am in Canada. USPS is trackable into Canada.
                      He is trying to unload 100 units, so I don't know why he won't sell global to support the members here that are global.
                      Either ways, he needs to post pics if he wants only the people in the US to buy.
                        Yes, I am in England and find this annoying, as I'd have taken 2 units too.
                          I am sure there are more suppliers with turnkey MD pole kits that ship outside of US.
                          Just order a TGSL-EDU from Silverdog (UK) and picking the coil housing form GEORGI (Germany). All I need is the poles.
                            You can pick up some good parts from this place, only drawback might be cost of International shipping.
                            Since 1983, Metal Detector is the trusted provider of the top metal detectors. Over 20 detector brands, competitive pricing & free shipping on metal detectors for hobbyists, professionals & security!
                              http://www.metaldetector.com/metal-d...poles-hardware
                              You can also get these from the UK ->
                              Other metal detecting supplies not in other categories. Includes Probes.
