How can I connect it to any pulse device?
  • How can I connect it to any pulse device?
ID:	454929 How can I connect it to any pulse device?
    AD620 High-Precision Microvolt Small-Signal Instrumentation Amplifier Module The AD620 microvolt signal module is a low-cost, high-accuracy instrumentation amplifier. It requires only a single external resistor to set the gain, which can range from 1 to 1000. It can be used for the amplification of both AC and DC signals. Technical Specifications of the AD620 Microvolt Signal Module: Input voltage: 3–12 VDC Gain: Adjustable from 1.5 to 1000x; zero-point adjustable Signal input voltage: 100 µV – 300 mV Signal output range: (Vin – 2V) Offset voltage: 50 µV Input bias current: 1.0 nA (max) Common-mode rejection ratio (CMRR): 100 dB Dimensions: 32 × 22 mm
    this might work if you build a completely new detector around this module. However, I doubt it can be used in any of the known detector circuits circulating online.
    It seems this module is designed for sensor applications.​
      I don't think it is particularly suitable as an input amplifier for PI detectors. Its slew rate is between 0.75 and 1.2 V/µs, and its bandwidth is around 1 MHz.
        I agree, it looks too slow.
