Here is an initial try at a more-or-less complete schematic. I still need to add some provisions for connecting to a micro. I believe the AFE is pretty much the same as I posted before. The TX schematic is close to what I've discussed, I had to make some minor changes to the integration loop to accommodate the eventual use of an ADC & DAC for digital control. At real high level, the TX looks like this:
The power circuitry is as discussed before. Here's a block diagram:
The positive boost is an option if I decide to pursue a single-cell lithium battery like a 26650. Right now I'm leaning toward (2) 18650 which makes the positive boost unnecessary. An identical boost has been added to drive the TX switches. Since 2 switches will likely be 1200V SiC MOSFETs they usually require a higher drive; I'm expecting 12-15V.
Overall, including a micro and audio, I think I can get this whole design under 2 watts. Either (2) 18650 or (1) 26650 has ~20W-hrs of energy so this will be 10hrs of run time on a charge.
[ATTACH]n411290[/ATTACH]
