I have read through the three books and I was interested in doing the Voodoo on the Nano. Has anyone tried that?
Voodoo on the Nano
The details can be found here -> https://www.geotech1.com/forums/foru...330#post301330Originally posted by sudhirkshirsagar View PostI have read through the three books and I was interested in doing the Voodoo on the Nano. Has anyone tried that?
- Likes 1
The schematics and PCB layout for Voodoo were done with EasyPC from Number One Systems.Originally posted by sudhirkshirsagar View PostI found the schematics of the main board as png's. Is there is a diptrace or eaglecad or easyeda version of the schematic?
Just to try something more accessible, the Arduino Nano PI Project was designed with DipTrace, and the Arduino Nano VLF Project was designed with KiCAD.
Whatever eCAD package is used will never be right for everyone. :remember
True. The ability to import different format exists in a variety of degrees in different packages. If a package is available for trial/free use, that helps.
I just bought the Nano VLF book (should arrive in two days).
I need to be able to identify the material of water service lines (if it is lead, copper or steel) and those are usually 4 ft into the ground. I think a hybrid PI with a 2 foot diameter coil for TX and a smaller coils for RX may work if I follow some of the findings from the four books. It is a lot to swallow for a newbie like me.
I think a synthesis of the technologies from the four is probably needed. For example, the best approach to get the +5V,-5V is probably in the Nano PI book. On the other hand, the Nano PI
probably does not do DISC the way the Voodoo does it. So between continual reading of the material in the books, diving into the their schematics, and getting advice in this forum, I feel somewhat positive!
Thanks for your helpful comments.
It would be possible to modify the Arduino Nano PI detector to use the Voodoo technique by adding a second preamp and a DISC channel.Originally posted by sudhirkshirsagar View PostI think a synthesis of the technologies from the four is probably needed. For example, the best approach to get the +5V,-5V is probably in the Nano PI book. On the other hand, the Nano PI
There's an Arduino adapter to replace the PIC in Voodoo, so you could use that as a guide.Last edited by Qiaozhi; 02-19-2024, 05:37 PM.
