Hi, all I have a question about the capacitors in my new barracuda kit, It comes with 3- .1j63 caps and 2- .1k63 caps for a total of 5. They are all 100n caps with different tolerance correct? Does it matter where I install the .1j and the.1k on the PCB? same question with the 4- 4n7100 and the 1- 4n7k100 witch are 4700pF with different tolerance. Also if anybody would happen to have a completed barracuda picture so I can compare mine to it and make sure I have all the caps in the right place that would be great. I have seen other pics on here but they all have a green board with gray caps, mine is red board with white caps.
Barracuda kit capacitor contents ?
Q3 and Q4 are back to back on the schematics don't think there are any others than the hand drawn ones.. As far as I know this is the only place where matched components help.Originally posted by Pin Head View Postnot sure what you mean by mirrored either. Trying to find better schematics.
Ok, so I should use the caps with the lowest tolerances closest to Q3 and Q4? You are only talking about +/- 5% for a J tolerance or +/- 10% for a k tolerance that's not that much. A F is 1% and the best high end cap would be +/- 0.1 pF. my opinion i s 5 to 10 % tolerance is close enough for what we are doing. I don't think it will work that much better with a lower tolerance. but what do I know I am not a electrician just a Certified emergency vehicle tech. ( not trying to be smart just stating a fact) I love learning what I can out here.
