Problem with my baracuda
  • Problem with my baracuda
    Hello all
    I'm french and was already on your forum there is some time
    I detected in France with xp gmaxII
    jai has resorted to the contruction of my pulse detector inductioin there some time already
    jai here has bought a kit silverdog's problem but it has not yet fonctione pay attention to components
    my 23 turn coil and 0.5mm 1.2 pensse that men but not enough inductance on this one but even with small coil POUEr trying it should work??
    diet have a 11 volt lipo was the opening of the switch there is not any sound of bipbip'm really disappointed because I had one e realization of aaz work very well with coil 1mx1m
    I do not have a measuring points on the pcb is not the forum desoler
    could you tell me because I know that among you are beefy in electronic of
    desoler my English but google reflecting
    thank you in advance to you : Rolleyes:
    Yep, Translator programs can make a red barn black. Take your time and do best you can. As stated on the Thunting.com site your inquired the same, it is best to build in Blocks. Get the power up and running. Check that it's working. This only takes a VOM. Next stage, Do the Preamp Stage. All you need to know is the right parts put in place and is the Chip getting power.
    Believe it or not you can check that too with a VOM. Output pin should be High or low with a target on coil. Tell me when your done with that!
      Hello there
      thank you to you for your help
      thank you my baracuda fonctione correctly now, what have the best reel for him
      jai for a flat coil has'm a forum member with a flat coil thread .... detected 35 cm a video on you tube but not found
