not trying to be q **** here, but i suggested this ages ago.
one thing we ALL learned about the baracudda is that it is very sensitive to coil movement, and the more shielding used the better, and that means encloseure coil and cable\coax.
typed on android keypad utter ****e.
Bara sensitive to motion. How to solve that problem?
ok so i thought i had sorted the movement issue but it is still there im using mic coax and it is cable tied to a carbon fiber shaft (it cannot move) even if the whole set up is out side and a meter above the ground it still beepbeep at the end of each swing also if i roll/twist the coil or move up and down? any ideas?
ok i have sorted the coil movement issue it was the coil cable movement causing the response issue yay something simple to fix!
Im not going to start moving components around, its just when i connect my coil i get the same issue any small movement and i get a response and the coil is about 1M of the floor
those are same FETs. identical. NOT DIFFERENT. do not take attention on that. I setted BF245's and they working in all places (inverted position of course).Originally posted by Koala View PostIn your kit did you not get 3 FETS two the same and one different. You could swap two over so Q3 and Q4 are the same. There was a discussion on the main Baracuda thread about a performance advantage of matching Q3 and Q4
Board is marked with different components for Q3 and Q4 ????
Yes, on board is marked different. I will try to swap. I hope this will help.Originally posted by Koala View PostIn your kit did you not get 3 FETS two the same and one different. You could swap two over so Q3 and Q4 are the same. There was a discussion on the main Baracuda thread about a performance advantage of matching Q3 and Q4
On my barracuda these two transistors Q3 and Q4 are different. Q3 is 2n5485 and Q4 is MPF 102. Should not they be the same? Baracuda is version Alex/Ap rev2
Don't you just hate it when that happens?Originally posted by 6666 View PostNothing has attached
What parts are EFE part of the circuit?Originally posted by Qiaozhi View PostPerhaps the Earth Field elimination is not working. That would account for it being ok on the bench (non-moving coil), but beeping when the coil is moved. Does it beep on the bench when a magnet is waved in front of the coil? Of so, then check the EFE part of the circuit.
I will try with microphone cable.
i built two barracudas, one as per kit, and another with ceramic chips, metal can transistors, .1 resistors, wima caps and millitary spec components where available.
i wanted to see if tighter tolerances made much difference, at first it was rubbish, it would beep at the end of the swing, tests proved it was the coax flexing that caused it.
after changing the coil wire to microphone coax it went away, after that it was excellent very stable, and yes higher spec components do increase stability, but not enough to warrant the extra cost.
after some chip swapping tests i found that ceramic texas instruments 40106 ic's, and metal can tip127(old very rare), made the most difference, after i changed these components in my other barracuda kit to these versions, it was just as stable.
i would look at the coil and cable worth a try.
