I have just finishes fiddling with a newly built barra. I have changed to a tip127 and also swapped the metal 2n2222a coil for a plastic one.
With the plastic 2n2222a in the orientation on the board i could detect a leatherman penknife at about 500mm but could not detect a titanium ring (that i could previously detect). After much head scratching and twiddling of the 25k pots...I decided to invert the plastic 2n2222a set pi 6 on the ic to 0v as per usual...and now it WILL detect the titanium ring at about 8inches +- 200mm but the leatherman only gets detected at around 250mm.
So I have gained sensitivity but lost depth of large objets....Does this seem correct...?
