Thanks Olly
Beachmaster Files
Hello Olly, I hope you are well. I have a few questions, if the use of those large potentiometers(POTs) is to adjust the pulse width and frequency, etc., then how are they different from small multiturns(RVs)? Second question: What is the best part instead of 2sd? Because I could not buy it
I apologize for my bad English
The Beachmaster is much more stable than the Polones in my experience.Originally posted by Olly View PostNo test video I'm afraid. As for whether it's better or worse than the Polones and/or ti12000, I really can't say as I'm not familiar with those.
I would say that it works as expected for a mono-coil, analogue, pulse induction detector. I like it, but then I'm biased
The PDF describes the functions of the Pots and the RVs. Each one is explained.Originally posted by hamedtaran View PostHello Olly, I hope you are well. I have a few questions, if the use of those large potentiometers(POTs) is to adjust the pulse width and frequency, etc., then how are they different from small multiturns(RVs)? Second question: What is the best part instead of 2sd? Because I could not buy it
The build document at Beachmaster_1.1.zip
paragraph 3.8 Sample Gates and Integrators
states at 3.8.1 the parts that need to be installed.
there is NO reference to R18 10k, and C9 470nf.
they are on the schematic and pcb.
i think it's a typo and it should be corrected
Thanks for pointing this out, these components are described under the preamplifier section 2.4 but as you have correctly indicated I have omitted to include them in the build description. I'll correct this in the next version of the file.Originally posted by nickel_n View PostThe build document at Beachmaster_1.1.zip
Does it mean that it is not possible to use a large coil in this circuit? Isn't this pi type circuit? I have built most of the pi circuits before, I want to try this circuit with a large coil, is this not possible at all?Originally posted by surfdetector View PostI think that you should build the Delta Pulse.
Yes it is possible. Please build it.Originally posted by hamedtaran View PostDoes it mean that it is not possible to use a large coil in this circuit? Isn't this pi type circuit? I have built most of the pi circuits before, I want to try this circuit with a large coil, is this not possible at all?
The Beachmaster should work fine with any coil size. I've only tested it with 10" and 8" coils but there's no reason that it shouldn't work with a one-meter coil.Originally posted by hamedtaran View PostDoes it mean that it is not possible to use a large coil in this circuit? Isn't this pi type circuit? I have built most of the pi circuits before, I want to try this circuit with a large coil, is this not possible at all?
I'd certainly be interested in your results if you choose to try it.
Thank you for your reply, I ordered the pcbs today, I will start making it soon.Originally posted by Olly View PostThe Beachmaster should work fine with any coil size. I've only tested it with 10" and 8" coils but there's no reason that it shouldn't work with a one-meter coil.
Hello, good time, my pcb order arrived from ChinaOriginally posted by Olly View PostThe Beachmaster should work fine with any coil size. I've only tested it with 10" and 8" coils but there's no reason that it shouldn't work with a one-meter coil.
please design this circuit to be able to increase the pulse width up to 300 microseconds, because as far as I know, using a large coil requires more pulse width. How do you think pcbs quality?Attached Files
