Originally posted by jeep6789
3 cells in series to give a nominal -12V and 2 cells in series to give a nominal +8V.
I'm doing it this way rather than the traditional approach of using a charge pump for two reasons: -
a) The current requirements of the Raspberry Pi Pico and LCD combination approach the max possible from a charge pump.
b) We eliminate the switching noise from the charge pump.
It is possible that current drain through the +8V and -12V segments won't balance and one of them will get flat before the other, which is why I have provided ADC monitoring of both levels so that the CPU can take the necesarry steps to warn the user and protect the batteries.
My intention is to have a separate battery pack mounted under the cuff with a 2-pole switch powering the detector.
I also intend to have a multi-way connector on the battery pack in order to balance charge the cells without having to remove them. (A multi-cell balance charger as used for model aircraft is ideal for this and I have a few kicking around).
Hope this helps,
