A Single Coil TEM field metal detector with simultaneous transmit and recieve.
  • peterr3
    Before any "big reveal" ... you should all read up on this Minelab patent : https://ipsearch.ipaustralia.gov.au/patents/2023204592
    Minelab are trying to lockup bipolar pulse induction till 2043.
    What is interesting if you follow this document trail you will see at that site that Nokta has raised an objection to that patent since it would appear that Minelab is possibly trying to patent the idea of a controlled constant current bipolar transmit scheme.
    Checkout the correspondence paper trail ( the lawyers are finding the gold here )
    It is every companies right to protect their own IP however reading the patent seems to indicate they are patenting the method of producing bipolar constant current transmit scheme ( eg using feedback loops, current sensing, controlled high voltage and low voltage connections across a coil at various timings ...etc etc adapted and arranged. )
    It is probable that the latest GPZ8000 model utilises this method. However it does require a separate recieve coil hence the horribly complex donut coil required on the GPZ8K.
    Food for thought ...
    What the examiner thinks of this ML patent.
    This document is an examination report for a patent application related to a metal detection method involving specific current control techniques, highlighting issues with support, clarity, novelty, and inventive step.
    Overview of the Examination
    • The report assesses the patent application filed by Madderns Pty Ltd for Minelab Electronics Pty. Limited, focusing on a method for detecting targets using a metal detector that involves controlling transmitted electrical current through inductive windings.
    • The examiner considers whether the application meets legal requirements for support, clarity, novelty, and inventive step, citing relevant prior art and literature.
    Key Issues Identified
    • Support and Disclosure: The claim defining the method lacks support because it omits essential features necessary for the invention’s operation, such as the measurement of the slope of the current during the first non-zero constant current period and the transitions between current states. The description indicates that these features are critical for achieving the claimed benefits, but they are not explicitly included in the claim, leading to inconsistency and insufficient support.
    • Clarity: The claim’s preamble states it is a method to detect a target using a metal detector, but the rest of the application describes the device’s operation and design, causing ambiguity. Additionally, the term "transition time" is unclear, as it could refer to a single point or an interval, but the examiner interprets it as a point in time, which affects understanding.
    • Novelty and Inventive Step: The application’s claims are not novel or inventive over prior art, particularly document D1, which discloses similar methods involving transmitting a sequence of magnetic fields with periods of rapid change and constant current, controlled by negative feedback loops. D1 explicitly describes measuring current slopes, controlling transition timing, and using feedback loops, all of which are features of the claimed invention. The use of multi-period sequences is considered obvious, based on common general knowledge, and thus does not contribute to inventive step.
    Prior Art and Literature
    • The examiner references multiple patents and non-patent literature, including prior patents from Minelab and other sources, which disclose similar methods involving negative feedback, current control, and specific signal sequences.
    • The search strategy involved extensive keyword and classification searches across patent databases and online resources, confirming that the disclosed features are well-known in the field.
    Legal and Procedural Notes
    • The application does not meet the requirements under the Patents Act 1990, specifically lacking support, clarity, novelty, and inventive step.
    • The applicant has 12 months from the report date to address objections; failure to do so will result in lapse of the application.
    • The next continuation fee is due in July 2027.
    In summary, the examiner concludes that the claimed invention is not sufficiently supported, lacks clarity in key terms, and is not novel or inventive over existing prior art, primarily D1, which discloses similar current control methods in metal detectors.
    He concludes: that the application, as filed, does not meet the statutory requirements for patentability!
  • Aziz
    Hi Paul,
    anyway. You gonna do with mono coil. This is nice, if ground noise isn't an issue.
  • moodz
    Btw,
    the coil need not to be IB type. Mono coil as TX, a smaller GB coil placed in the center position (seperate RX) with a few turns should do the GB channel for GB info. The GB coil would detect during the high dI/dt the GB info. There wont be high voltage on the GB coil.
    GB response is 1000 x more than target response. Enough for GB without losing much target response.
    Huh ? You already have a coil .... "the monocoil" .... we dont need another one.
    There is no point in me ( and the AI ) spending all this brain power and tokens to simplify the coil down to one simple coil and now you want to add another one ????
    The GB is very simple ... you get it from the signal .. ( the rx signal is Self detection + Ground signal + Target ( sometimes).
    We balance out Self Detection and Ground and you are left with Target.
    Just to prove the point I tweaked the earlier code I use on the E class transmit ( using an IB coil in that case ) ... and now we get the discriminating monocoil TEM with GB
    What we are looking at below is channel 1 and 2 ( virtual DSP channels in the software ) showing target responses and virtual channel 3 is the GB balance channel but also once balanced responds with Fe / Non Fe info. ( +ve for non iron ... -ve for iron ... no response for ground )
    The response are not as strong ( its a cancellation channel after all ) in the GB channel but we only need the sign of the signal to disc the target.
    There are 3 non iron targets then two iron targets.
    This is not a simulation ... its straight off the test platform.
  • Aziz
    Btw,
  • Carl-NC
    After thinking about it some more, that's what I expected. EFE is common-moded on the entire waveform, so if it causes the +peak to increase to +peak+Δv then the -peak should also increase to -peak+Δv. Reflected to the load resistor, you should see a +Δv after the rising edge and -Δv after the falling edge. When averaging multiple sample, EFE disappears.
  • peterr3
    Nokta objection to the patent is 24 pages and i am told is being backed financially by the Turkish Gov. Nokta have lodged their own patent for their new PI detector the Magnetar 9000 which is ZVT based.
  • moodz
    Does this mean we need to re-introduce EFE samples? Swing a big magnet and see what happens.
    I would say no ... the coil is reversed on each edge so the EFE induced voltage is too.
    Waving a powerful magnet seems to confirm.
  • Carl-NC
    No amplification. Pulse rate = 10 khz. ( Scope says 20 khz but there are two magnetic transitions per cycle )
    I consider the detection edges when quoting the pulse rate. In this case, it's really an effective 20kHz pulse rate.
    Even though the mag pulses are bipolar the RX signal come out as unipolar ... which is nice.
  • Orbit
    Two months ago I was involved in experiments for the Volvo car industry with a friend who is working on a patent for wireless energy transfer between robots. And I wasn't committed to the detectors. But I was encouraged by this thread using a mono coil for transmission and reception with discrimination decided to repeat my experiment on the GT for which the Altra detector is fully functional with a DD coil works perfectly in the field. So I can't put an oscillogram against it! But I used the GT as a platform and changed the input part and some other things on the basic schematic and attached my mono coil which is wound in a very specific way, nothing like that I haven't noticed anyone mention anywhere. The result is on the video, in the next few days I will set aside to turn off the double tone when the iron is crossed and maybe replace a few other things so that in a few days I could get a fully usable detector with a mono coil and bipolar transmission that has excellent discrimination and ground rejection on one channel.https://youtube.com/shorts/iLerw0GsR...Xi6ea7g0cDw9OG
  • Aziz
    Hi all,
    I for one would still run a concentric co-planar IB coil for this transmitter.
    This is the reason for:
    Two channel processing. TX is the main target channel (including ground noise).
    A small RX coil with a TX bucking coil is the ground channel. It detects 1000 times more ground noise as the coil coupling coefficient k will be affected by the ground mineralization.
    This ground channel will be used to clean the TX main channel (removing ground noise).
    The TX channel could be integrated over a very large window time (single integrating window).
    We don't need much inductance for the RX coil. RX and TX bucking coil could be really small size too. The TX coil will still pick up deep gold.
    Now go for it!
  • mickstv
    Thanks for that. I think I still have the circuit built from when I was playing with the bipolar alternate TX that you posted. So just add a few extra bits and see what happens....
  • moodz
    Originally posted by mickstv View Post
    Hi Paul, looks interesting. Any chance you can post a YouTube with it running and showing us how it reacts on the oscilloscope to different objects like ferrite core, aluminium, lead. I guess on the raw input, unless you have a preamp strapped to it now and for a complete cycle, thanks.
    looking at one of the mosfet gate drives and the raw RX signal.
    Blue = no target.
    Orange = Iron
    Green = aluminium
    I cant really post a youtube as there is a factor of demonstrating features in the public domain that are the subject of patents.
    Click image for larger version  Name:	image.png Views:	0 Size:	1.64 MB ID:	448119​
  • mickstv
  • Riss
    whether in simulations or real circuits ... resistance is does not affect current sources ... we just dissipate more power.
    A 1.0000 amp current source is a 1.0000 amp current source through 1 ohm or 100 ohms.
    This is undoubtedly true, but the higher the resistance of L1, the smaller current will fluctuate in L2
  • moodz
    Hi all,
    it seems, that Paul has found his magic choke L1 too. It is really magic and a great invention.
    We are of course very much interested in it's performance in the field. I am sure, Paul is working on this.
    With an IB coil (TX, RX), a two independent channel version can be realised to get maximum of target/ground information.
    For magic chokes we will use something like a gyrator to replace the inductor.
    The circuit below is an example ... it directly replaces the inductor.
    The inductance is proportional to R^^2 x C ... so its very easy to make "inductors" of several henries with very high impedances.
    The downside is that you lose more power than with a simple inductor, the upside is that you have lovely untilted pulses.
    PS This is not magic .. the gyrator was invented around 1948.
    PPS the patent claims cover its usage.
    Click image for larger version  Name:	image.png Views:	0 Size:	14.1 KB ID:	447965​
