PI CHIP
  • maxfly
    Hi moods,
    Just wondering if you are able to supply one of your latest version chips pre-programmed, or even better some sort of kit? I'm only just starting into this type of work but am willing to give it a go! The capability is amazing.
    Cheers
  • moscadondres
    6666 and moodz,
    The post is #136 with:ground balance,descrim balance in(UNIPI DS V230)where ican connect these 2 to UNIPI V3 Universal,sorry and thank you.
  • moscadondres
    6666 and moodz,
    Thank you but how connect the post#133:THAT510 with UNIPI V3 universal,may be is not possible.
  • 6666
    Sorry I thought he was asking about post #144
  • moodz
    The front end posted here will work ....
    A differential front-end PI design originated by Moodz and open for community development.
    However this if for experimenters ... it is not a paint by numbers instruction. It has been tested but needs some finessing to reach optimal performance. You should be able to see where to connect the TX and sample pulse.
    moodz.
  • 6666
    moscadondres
    I think I can see what you are asking from post #144
    the audio pin seems to be pin33, you can have up to 4 samples from pins 22,18,22,19
    not sure what Moodz is using for the TX, best for him to answer that
  • moscadondres
    hdphilip,
    Thank you for reply,i don't work with 4011 and 4012 chip because i don't know where i can connect :sample,Tx,signal out and discrim balance of post 133;regards.
  • hdphilip
    moscadondres,
    i've been working with the 4012 chip with the feild test unit, i will say i've been impressed with moodz software for that chip, i did breadboard the 4011 chip, if your going to use the 4011 chip, let me know, and i'll see if i can figure it out for you. from what have.
    Philip
  • moscadondres
    Hi Moods,
    i would like know how and where i can connect:sample 1 pulse;Tx pulse;signal out;discrim balance control in of your post:133 called field test unit n001 at these post:144;thank you for reply.
  • hdphilip
    CPU speed
    moodz,
    I tried the 20MIPS code, i saw that you put 20MIPS on the second line to warn us on the slower speed
    here's what i noticed (this was from my breadboard setup)
    I also measured about 100 ma with the LCD display on.
    At 5 volts worked fine.
    The "update time" on the display seemed half as fast. (harder to read)
    The 20MIPS software would be an excellent choice in troubleshooting,
    when I programed it on my pickit 3, because of the lower operating current, i found the
    pickit 3 was able to power the CPU and LCD . which the 40 MIPS software couldn't.
    I'm using the 30 MIPS CPU.
    we could use a switching regulator for the digital +5 volts, from our battery pack to help the overall efficiency.
    faster the better!!
    I reloaded the v300, the cpu is purring along at 5.2v , waiting for a PCB, when I get the PCB made i'll try the menu/ timing functions
    Philip
  • moodz
    Here is a version of the 4011 code running at 20 MIPS instead of 40 MIPS .... the internal cpu clock is now 80 Mhz instead of 160 Mhz and well within the 120 Mhz manufacturer spec. I have not extensively checked the menus and timings so any feedback is welcome.
    The current draw is now 115 mA ....
    moodz.
    UNIPI_4011_20MIPS_hex.zip
  • moodz
    Originally posted by hdphilip View Post
    hello Moodz,
    thanks for the update, (i was inputing the design into eagle)
    When i was breadboarding the CPU and display i noticed the LCD was inter-tied with the icsp witch was also sending the menu too.
    One important item i noticed, after about ten minutes, the display would lock up, sense we're overclocking these chips, i increased the voltage to about 5.2 volts, which seemed to do the trick, the current draw was about 200ma, with the LCD on.
    I see you added some buffer stages for the sample/pwm outputs, is your thinking along the lines of to provide some sort of isolation, and to eliminate the need for the mosfet drivers?
    If you were to use the ADC on on the SPI line, would that free up some CPU overhead, and would it be best to mount ADC on the front end board?
    I did not need to increase the voltage to overclock these chips however any noise on the +5 logic supply will cause a lock up ..... could depend on your chip production version also .. they vary slightly. I will look into running the chip at half the current clock speed.
    moodz
  • moodz
    Amazing Moodz
    where did you get the Evaluation Board
    cannot quite read the writing ?
    cheers
    My evaluation board is one of the chips soldered to an SSOP chip carrier
    The factory evaluation board is quite pricey. ( about $160 I think )
    moodz.
  • hdphilip
    hello Moodz,
  • 6666
    Amazing Moodz
    cheers
