Hi All,
I have just started a build of a Geotech Baracuda (Rev-A) Kit from Silverdog and have struck problems at Step 1. I have fitted PL1, C4 (220uF), D3(IN4001) and U3 (78L05) as per instructions. The voltage check at at U7 pin 8 gives +7.6V , not +5V. I am using 8x1.5V AA batteries in a pack as the power source that reads 12.7V as an input voltage. I have quadruple checked the component orientations, soldering connections and wiring and it is all ok. The 7.6V o/p is out of spec according the the documentation for the 78L05 so I am going to change it and see if fixes things. Does anyone have an opinion on what might be wrong apart from a faulty regulator ?
Thanks for any advice.
cheers
Steve
cheers
Steve
I got home from work, tested and voila +5.1V. I must have misread the diagram and been testing from the battery +ve to U7 pin 8 which thinking about is ~ 7.6V given my input voltage reads ~12.6V. I suppose it was late at night and I was tired but still I can't believe I did that. I will be more careful next time. Thanks for your assistance.
, but that you'd used the +ve battery terminal as the 0V reference.
It has been a quite a while since I have done any electronics theory and it is slowly coming back to me.
