baracuda rev A silverdog bad performance
  • rdz28
    I forgot to say one thing, for the test I'm not using a battery pack, but a power supply with vdc output set naturally on 12V
  • Andi68
    I wish you success
  • rdz28
    tonight I'll try with an oscilloscope and post the images
  • Andi68
    Gram of course
  • green
    Originally posted by Andi68 View Post
    I do not Need a Bara any more.
    I want to build a detector that finds a 1Gr gold nugget at 70cm depth
    Gr=gram or grain?
    ​Me too
  • Andi68
  • kt315
    I built the version of kt315 and at 0V at pin 6 of the 5534 the circuit did not work.
    Only at a setting of slightly more or less 0V, the circuit works.
    Make a try and adjust the voltage on the 5534 in the range of + or - 0.5V
    i do two DP boards on order and no time on Bara. odnako i will do still one video with reaction of my Bara on metal.
  • kt315
    The signal at pin 6 of the 5534 (preamp output) is dynamically changing. You cannot set the null-offset adjustment using a multimeter. An oscilloscope is required to adjust the null so the signal settles at 0V, not so that the average voltage is 0V
    first of all he must check all operational amplifiers by special tester. its easely. just set and look on LEDs.
  • Qiaozhi
    Originally posted by rdz28 View Post
    [ATTACH]44413[/ATTACH] 5534 measure 0.0V to pin 6
  • Andi68
  • Tibuck19
    Can you post a clear photo of your board with the components on it, It starting to sound like you have perhaps placed the, poly film capacitor's in the wrong spots.
  • rdz28
ID:	352376 5534 measure 0.0V to pin 6
  • rdz28
ID:	352375 u7 pin1 volt -3.62 and I can not adjust it to -2.1volt
  • Andi68
    Have you measured in the right place - IC 7, pin 1?
  • rdz28
    I know but I do not understand what .. I did everything as the guide said .. but I still can not adjust u7
