Delta pulse
seems good. why on the board its are not good? resolder and do right. be accurately.Originally posted by Kubi2323 View Post[ATTACH]51056[/ATTACH]
anotherway your board will turn in garbage. First Rule. accurately soldered board is working
right from power up connection. you did unaccuratelly.
impossible both leds are lighting. something wrong.
or some part have a problem???
every component has to be checked before soldering, by measuring. resistors, caps, transistors, etc, all.
if you do not do that (laziness) you get headache. what type vt10 vt11?
also, i see you bend components' pins on bottom board side, FOR WHAT YOU DO THIS???
WHAT THAT GIVES TO YOU??? if you desolder something with bended pins you WILL KILL HOLES' METALIZATION - !!!
if you are beginner ASK BEFORE TO DO SOMETHING.
