Let's start from square one...
  • Carl-NC
    The question is, does the mono-coil provide any befit other that simplicity of design or ease of interface?
    Coil weight?
    While we consider the area of coils (funny how we jump from PS to coil), is there any benefit (S/N) of a centertapped RX coil feeding a differential input stage?
    Maybe, but I don't see it off-hand.
    Originally posted by GT Blocker View Post
    J.L. King,
    "While we consider the area of coils (funny how we jump from PS to coil),"
    Actually, since powering the coil and the board are so inter-related, I think that's a great topic to go with the pwr supply Q.
    I agree, don't put off the power supply until the end, but consider it up front, and make changes as necessary.
    I do have another probably dumb question, however...
    Would there be any benefit to using separate batteries for the coil and the rest? Just a thought.........
    While it might be more efficient, I don't care for this approach. I prefer a single battery (pack).
    you can still use a charge-pump DC/DC converter for the analog part. This should be controllable, which means, it should be deactivated by the micro during critical sampling processes. This can be done via PWM output disabling to avoid clocking of the DC/DC converter. Never use a DC/DC converter you can not give the clock timings. The DC/DC converter must be synchronized to the micros clock.
    Certainly if you use a switching reg, it should be synchronous. But it can still cause problems because, as the load current varies, the impact of the switching reg will vary.
    The charge pump also helps with the LI-Ion polymer batteries. These batteries pack a lot of power for little weight, but have the problem of a wide range of voltage.
    Example: A nominal 14.8V LI-Ion polymer battery has a peak voltage of 16.8V and a cutoff at 11 Volt. This is just too much range to use without regulating.
    Do you mean for the coil TX circuitry, or all the circuitry? The TX circuitry can tolerate a lot of variation. Everything else needs to be regulated, but not necessarily using switching regs.
    - Carl
  • Tinkerer
    I tend to agree, but I was hesitant to eliminate an option that may be beneficial. All of my limited experience has been with dual-coil. I tend to prefer them from a performance point of view. The question is, does the mono-coil provide any befit other that simplicity of design or ease of interface?
    Rergards,
    J. L. King
    I don't see any advantage in the mono coil. My reasons for wanting a high TX voltage are for experimenting with entirely new and different methods involving several coils.
    Power consumption and battery weight have always been
    the major problems with PI detectors. To solve these problems would be a considerable improvement.
    Tinkerer
  • Aziz
    Hi all,
    See the SPICE circuit simulation for some ideas (the second rar-file):
    You will also see the regulation of the transmit coil power!
  • GT Blocker
    coil vs PWR
    J.L. King,
  • KingJL
    My preference is to ditch the voltage doubler charge pump, which means no mono coils.
    Rergards,
    J. L. King
  • Carl-NC
    Some good ideas on supply design. I spoze the first thing to decide is whether to support a mono coil, as that puts some limitations on the supply configuration. My preference is to ditch the voltage doubler charge pump, which means no mono coils.
    The next decision is whether to use any switchers at all, or to use linear regs. I think for a first cut go with linear only. Later try switchers and see if they cause a problem.
    - Carl
  • Tinkerer
    The need for 3.3V is mainly dictated by the uPC part that you use. For example, the 18F4550 is available in a 3.3V (18LF4550) or 5V part. If you notice Carl's board, he provides regulators to accommodate either. The reason to use a 3.3V part is reduced power dissipation requirements (it starts to make a difference as you get to higher clock speeds). As you get to higher clock speeds you will notice that the uPC's are available only in 3.3V (e.g. PIC32 @ 80MHz).
    J. L. King
    Thanks for the explanation.
    Tinkerer
  • gwzd
    J. L. King
    The low voltage PIC devices such as the one you mentioned PIC18LF4550 are limited in frequency. I remember something like 20MHz at 3.3V. I used once the PIC18LF4520 and never looked back, lots of problems with BOR and sometimes with the ports. While they are supposed to be 5V tolerant, well they are not, sometimes they worked sometimes they didn't. I haven't had experiences with the PIC18LF4550, mainly because of the bitter memories involving the 4520, perhaps they got it better with that one. Anyway, after that incident I try to use PICs only with 5V power rail being able to run then all the way up to 48MHz.
    However, if I could pick then I'd rather pick any of the Atmel devices. The USB thing with Microchip never impressed me much, I think it was a little bit too "microchip's way" of doing things. A silicon labs chip, or if you think 8Mbit/s is OK for you then even a FTDI FIFO can be much more docile to handle.
    If you don't need that high speed, but need to be nice to your battery then the TI MSP430 series are a much better choice.
  • gwzd
    I can see why the power management is seen too last. There are so many choices to be made along the way, so only at the end you know how much power is going to be needed.
    At the beginning there can only be an educated guess. So let's guess how much power we need on each voltage.
    About Traco power. The ones I looked up, are very noisy. Maybe I looked at the wrong series?
    Tinkerer
    Which ones did you look at? Check the TEN5 series, if my memory doesn't fail me they have a couple of millivolts peak to peak overy a couple of tens of MHz bandwidth. They switch at 2 or 300 kHz, which is not much of an annoyance for what you want to do. However, don't use these kind of stuff without a good filter at the output. If you want to get paranoid then pick then with a voltage a little bit above than the one you need and post regulate the power with a suitable LDO.
  • Tinkerer
    Tinkerer
  • KingJL
    Then we need +3.3V for the PIC. here is a question:Why 3.3V and not 5V? because of the noise? 5V would make it easier for driving the Mosfet driver.
    J. L. King
  • gwzd
    Then we need +5V\-5V for the signal line with a noise free GND.
    So do we regulate at 12V to use as GND? Or virtual GND? For how much power?
    The specs are not that bad, but you forgot to specify the current consumption.
    Lots of questions and still many more if we take the battery control and charging into consideration.
    There are many choices out there for that, many of them chemistry independent. Once you have decided the kind of battery, then perhaps I could help you out with that.
    All in all, the power management for the MD turns out to be quite complex.
    It is exactly like that more often than we would like to admit, power management is always relegated to the end development phase for some stupid reasons.
    If you are not very constrained with prices then use a trick that works for me every time I don't have the time, but have the money: use ready made modules.
    There are many out there, but one that has worked for me always is Traco power. You can see what they have here:
    All major suppliers like Arrow, Newark, Farnell etc have them, not cheap, but reliable and easy to use.
  • Tinkerer
    Power supply
    Originally posted by gwzd View Post
    My eyes are not what they used to be! Can you post a bigger/clearer picture?
    A few years ago I needed something similar to what you need now +5, -12 and +12VDC. I only had 7VDC available, so I made the little board in the picture to test how could I tackle the problem without having to get a flyback transformer. This little board happily delivers +/-110mA (Tested) on the +/-12Volts rails and 500mA on the 5Volts rail. I must have the schematics and the gerbers somewhere in one of my backup disks, if you want I'll search for them, if this is too much for your MD then I'd rather not search anything. Oh, the output capacitors are rated only at 10Volts, but that is at 105C and I didn't have others and my board was cold, so I used those instead of the 16Volts intended in the schematics.
    Thanks for the offer. For my present need, the charge pump supplied by KingJL, will do just fine, specially since I have the parts on hand.
    However, I would like the help of experts, to design a complete, efficient power management for the new generation of PI detector.
    Starting with the batteries:
    LI-Ion polymer seem to be the best choice.
    Voltage? The nominal 14.8 Volt battery has a peak voltage of 16.8V and a cutoff of 11.0V
    This is a very large variation to drive the TX pulse directly. So we need to regulate the TX drive PS.
    Using the charge pump, we could regulate at about 19V. This is fine, driving the TX from -Bat to +19V.
    Now, how much power do we need for each voltage?
    TX about 0.3W or about 16mA
    How much for the PIC, including the LCD?
    How much for the signal processing line?
    Could we make a rough estimate of the power needed?
    How do we get a low noise but efficient +5\-5V for the signal line.
    Switching regulators? what is the noise figure?
    Any help is much appreciated.
    Tinkerer
  • gwzd
    Here is another power supply. I want to use the higher voltage V+ to drive the coil from -12V to V+.
    Since I am using an IB coil, the RX coil can be on GND to +5V.
    5V-VDD to drive the PIC
    Will this work?
    Any suggestions to improve the circuit would be welcome.
    Tinkerer
  • KingJL
    KingJL
    Thanks for the help.
    With the Darlingtons there will definitely be enough power. It has been mentioned that the linear regulators are old fashioned and have low efficiency.
    The modern switching supplies are much more efficient, but what worries me is the noise factor.
    How does the noise of the capacitor charge pump compare with the noise of a switcher regulator?
    Tinkerer
    Tony, I honestly do not know. I haven't explored the switching regulators. I would think that any noticable noise caused by the charge pump would be on the -12V line. The +-5V lines should be relatively clean as long as their input voltage is >6.5v. I haven'y noticed a noise problem from them. If you load the output of the regulators to the point that they draw down the inverter output lower than 6.5v, then you will start to get noise.
    J. L. King
