Hello. After adjusting my HH1 and test it I found a big problem of ground effect, difficult to solve with adjustable presets, Then I followed the advice of Reg:You might try reducing the power into the coil some by simply adding a 25 ohm resistor in series with the FET. At first, one will worry about a possible depth loss, but you will be surprised how little is lost. I put a pot in series and the problem went away, I had to find a middle between eliminating the ground effect and greater sensitivity, but it really worked, thanks, see you soon.
ground effect problem solved
One more proof, that brute force approach provide more loss than obtain.Originally posted by olecram1 View PostHello. After adjusting my HH1 and test it I found a big problem of ground effect, difficult to solve with adjustable presets, Then I followed the advice of Reg:You might try reducing the power into the coil some by simply adding a 25 ohm resistor in series with the FET. At first, one will worry about a possible depth loss, but you will be surprised how little is lost. I put a pot in series and the problem went away, I had to find a middle between eliminating the ground effect and greater sensitivity, but it really worked, thanks, see you soon.
