Hi Carl
Why are you not calling your detector "Geotech PI"? Sounds not bad. Or?
I had a closer look at your PI-1 circuit and found that in your next revision you should connect PIN 7 of IC7 as well to digital ground.
This makes in function no difference but from my point of view belongs IC7 (the control) to the clock circuit and should be connected to digital ground (-5D).
Which function has the var. resistor R33?
And what is AutoTrack Speed?
Chris
Chris
