Threshold Pot doesn't work
  • h9361
    Click image for larger version Name:	image.png Views:	0 Size:	33.4 KB ID:	453535​
    However, according to post 688, your circuit does not have a bipolar TX so you cannot use this. You will need to use something like this:
    Click image for larger version  Name:	image.png Views:	0 Size:	16.0 KB ID:	453536​
    I adjusted this timing, all sample width is 20us.
    Click image for larger version  Name:	diagram.jpg Views:	0 Size:	66.2 KB ID:	453538
    Ch1 = Tp5
    Ch2 = Tp6
    video1 : testing foil
    video 2 : testing Iron hammer
    I am using a small coil, a rectangle coil 10 * 5 cm.
    If i put hammer very closely to coil, i hear a two fast beep, this happen only for iron, not foil.
  • Carl-NC
  • h9361
    Your videos show that both sides are doing the exact same thing. One side should do this:
    And the other side should do this:
    My guess is that your demod timing isn't right. What are you using to test GB? Because those videos tell me that GB can't possibly be working.
    And, no, whether the preamp is inverting or non-inverting won't make much difference.
    OK.
    Please tell me your suggestion for timing (TGT, GB, EFE1, EFE2) and i will test it.
    Do you remember your timing for Bipolar?
  • Carl-NC
  • h9361
    If you are getting the same response for all conductivities, then GB is probably not working.
    300uH and ~470Ω. This is not your problem. All you need to do is make sure the preamp is no longer saturated when the first sample starts.
    Look at TP5 and TP6. For any target they should have opposite polarities. For a small (25mm square) foil target TP5 should be stronger than TP6. For the hammer TP6 should be stronger than TP5.
    I checked my PCB more and more, the only difference was 4066 pins (3,4,10,11).
    I attached final schematic.
    Click image for larger version  Name:	newGB.jpg Views:	0 Size:	129.2 KB ID:	453523
    See following, it is U7: pin8 and pin7 output when Iron and foil are in front coil. Both target form is the same.
    Ch1 : U7: pin 8
    Ch2 : U7: pin 7
    Click image for larger version  Name:	iron1.jpg Views:	0 Size:	130.0 KB ID:	453525
    I tested my GB, it is working very nice.
  • h9361
    Thanks.
    I captured two videos from my scope.
    Ch1 = TP5
    Ch2 = TP6
    Video 1 : target was a foil.
    Video 2 : target was a iron hammer
    Both target has the same action.
    Please see my 5532 inputs,
    my input signal is connected to pin3 (+), whereas Mr. eduardo1979​ advice me to change it. It should be connected to (-).
    Do you think this problem is because of it?
    I read Ivconic's posts, he had my problem too (his post).
  • Carl-NC
    Originally posted by h9361 View Post
    No difference in audio. GB is working nice, but disc audio is not work.
    During capturing video for Bipolar, do you remember your coil inductance and damping resistor?
  • h9361
    What targets are you using? This method does not discriminate between ferrous & non-ferrous, but between low conductor and high conductor. Try a small piece of aluminum foil.
    Dear Carl,
  • h9361
    I tested with :
    an Iron nail, Hammer and Pliers
    1-euro coin, small and big foil, copper glass,
  • Carl-NC
    I checked the "A" point on scope, no difference. All targets first increase.
  • h9361
    If you probe point "A" in your schematic, does it increase for one type of metal and decrease for the other?
    Do you think it can be because of my damping resistor (680R)? Maybe the value is high.
    Should I change the value of this resistor to 330 ohms and use a new inductance?
  • h9361
    Originally posted by eduardo1979 View Post
    Your timing settings might be incorrect, or the connections to the CD4066 synchronous demodulator are likely wrong. At point A—with the GEB potentiometer set to a mid-range position—high-conductivity metals should produce a response opposite to that of low-conductivity metals. In my opinion, you should check point A first, just as Carl suggests, before looking for the problem in the audio circuit.
    Dear edurado
    TGT = 10us
    GB=10us
    EFE1=320
    EFE2=340
    All sample width is 20uS
    I attached scope for GBdelay (9.5)
    My testing targets are a foil and Iron hammer.
    My coil size is 10cm, it is small for testing.
    Click image for larger version  Name:	dels.jpg Views:	0 Size:	98.8 KB ID:	453410
  • eduardo1979
  • h9361
    My GB is working, but no disc on Audio.
    My coil is mono, 500uH+680R.
  • Carl-NC
