Hi All,
Well, I got a chance to use my HH for nugget hunting. This time, my search was going over old dredge tailing piles. Now, the HH seemed to work fine for where I was hunting. Also, I did have mine set up to use the mini amp I mentioned in an earlier post.
As mentioned, the PI worked fine for searching old tailing piles, but seemed too sensitive for regular ground with the mini amp installed.
I do need to go back and try a few things more. Hopefully, I can do that in a week or so.
My HH is set up to use DD coils, which is what I had installed. Even with a DD, the mini amp caused the PI to be too ground sensitive once I was off the tailing piles and over regular ground. At least, it was at this particular location. I could reduce the pulse width and minimize this problem but this did reduce the sensitivity also.
I will post more once I do a few things and get back for a second test.
Reg
Reg
