hey guys i know im late to the party but somehow still have trouble with such an easy and ancient circuit so i was building mine and everything went almost smooth and i say almost cause i was so puzzled to why my q3 getting so hot then found out my ne555 need a resistor which i placed in the back of the circuit anyhow fixed that . my build is option 1 vco audio passive pull down my coil is 22awg 25 turn 10 inches my powersupply is a 12v atx (which i know it might cause trouble but im not sure i dont have a battery yet) so heres the problem i have a weird noise on the whole circuit like when theres nothing close to coil the audio just peaks for no reason i tried to calibrate again and again but no luck also my threshold doesnt seem to be working all my ics are correct except the 2 ne555 which are not cmos and i have questionable quality of all my componants especially capacitors because i swapped 2 because of leakage which gave me a headache to find out i am very confused to why i cant get this to work and cant progress to fine tune or test because this noise is not letting me thanks in advance.
Lots of trouble with hammerhead
Is this the original Hammerhead circuit board? Or is your own PCB layout perhaps also experiencing problems? Typical sources of interference include fluorescent tubes or old televisions. The Hammerhead project is several years old and has generally never caused major problems. Many have successfully completed the project. That alone should make you wonder if you might have done something wrong. Another possible source of problems could be that you bought or used cheap or counterfeit components. Only buy from reputable dealers.Originally posted by milad1 View Posthey guys i know im late to the party but somehow still have trouble with such an easy and ancient circuit so i was building mine and everything went almost smooth and i say almost cause i was so puzzled to why my q3 getting so hot then found out my ne555 need a resistor which i placed in the back of the circuit anyhow fixed that . my build is option 1 vco audio passive pull down my coil is 22awg 25 turn 10 inches my powersupply is a 12v atx (which i know it might cause trouble but im not sure i dont have a battery yet) so heres the problem i have a weird noise on the whole circuit like when theres nothing close to coil the audio just peaks for no reason i tried to calibrate again and again but no luck also my threshold doesnt seem to be working all my ics are correct except the 2 ne555 which are not cmos and i have questionable quality of all my componants especially capacitors because i swapped 2 because of leakage which gave me a headache to find out i am very confused to why i cant get this to work and cant progress to fine tune or test because this noise is not letting me thanks in advance.
yes this is a handmade fiberglass pcb the noise im talking about is not around noisy things type of noise the noise is completly random even when i put it in a non noisy area i also shileded the coil . as for the componants my ics are from trustable resources my resistors are fine what can really go wrong there the only dodgy ones are my capacitors which i have used new ones and some stock ones taken out of good quality boards i should mention again the noise is very random and it peaks a lotOriginally posted by GeoMax View Post
Here is the video and this is what happens at first i turn on my power supply (im not using batteries yet) after a few seconds u can hear the noise every time i even power cycle at the end to show it second thing is that when i move a huge target like a phone its a bop noise not a vco noise and third thing u can see threshold dont work and moving r42 stops the noise as long as its moving and as soon as it stops noise comes back next thing is r3 which make weird noises againOriginally posted by nejdet View PostShow the circuit board you’ve built, and make a video showing the problem!
Hi milad1
I watched your video. It sounds like a signal isn't connected correctly or is undefined. Your circuit board is homemade, right? Could you post a picture of the trace side? Maybe then we can see more of what might be wrong. First, I would check all the solder joints and traces for contact and continuity. You might have a hairline crack somewhere on one of your traces. That happens quite often with DIY boards.
Here they are i dont think the solder job was that bad i dont see any obvious shorts and the blue things u see are just left over soldering masks from failed solder mask attempts and not cracksOriginally posted by GeoMax View PostHi milad1
I watched your video. It sounds like a signal isn't connected correctly or is undefined. Your circuit board is homemade, right? Could you post a picture of the trace side? Maybe then we can see more of what might be wrong. First, I would check all the solder joints and traces for contact and continuity. You might have a hairline crack somewhere on one of your traces. That happens quite often with DIY boards.Attached Files- ۲۰۲۶۱۱۱۷_۱۵۲۱۴۵_compress86.jpg (383.8 KB, 0 views)
