I want to verify this part of the build instructions:
Short pad 1 of IC8 to a convenient
ground (simple to do when using IC
sockets — IC9 pin 4 is ground). This
should never be done with IC8
installed. R24-R26 is now a simple
voltage divider, the same as R25-R27.
A DC voltage can be applied to R23,
and if there is a mismatch in the two
dividers, R23 can be adjusted to null it
out. This should be done with the analog
gates turned on, which will be the
case as long as Q8 & Q9 are not
installed.
Use a voltmeter to measure the voltage
at TP4. Adjust R18 until this
voltage is maximum. Now measure the
voltage across pins 2 and 3 of IC8, and
adjust R23 until it is zero. Readjust R18
until the output of IC6 (TP4) is 0 volts.
Remove power to the board, remove the
ground short to IC8’s pad 1, and install
R5, IC8, Q8, and Q9. Set R31 to its
midpoint.
l
Is the second paragraph the proceedure described in the first paragraph or do you have to apply a voltage to R23, match the voltages, then do the proceedure in second paragraph? I'm am using 1.0 % resistors for R24,25,26,27.
Sorry if this is a bonehead question but I'm just learning.
installed.
midpoint.
l
I'm trying to be very careful with this one.
