Has anyone successfully modified the auto-tune section for better performance. There appears to be significant potential for improvement in this area. TP 5 indicates plenty of dynamic range remains (that follows target strength) between 0 and +5 left even after the signal at tp9 becomes erratic. It seems that the dynamic range of the circuit of ic8b is very limited. I would be interested in exploring options in this area. Maybe something to give a more lograrithmic response (high sensitvity at lower signal levels, with senstivity decreasing as the voltage at tp5 increases ). Maybe more filtering is required in IC8a, ic8b to take advantage of the target signal dynamic range of in ic8a.
Thoughts?
Thoughts?
Criticize away! HH certainly has its issues. But, as I've always said, it was never intended as a build-and-use detector, but rather as a learning platform for PI. I'm glad to see you're doing just that, and taking it in a new direction.
