Any more thru-hole PCBs for HH?
  • Any more thru-hole PCBs for HH?
    Greetings, Carl. Recently found this website. This is absolutely great!
    I'd like to build (experiment with) the HHd1. Are there any more boards available? Or could you please update the link to the GIF file for the HHd1 thru-hole board so I can make one? The link currently appears to be dead.
    Thanks.
    I guess I could do it again...
    Hey oldjet,
    If I can be sure of selling at least 6 boards, I guess I could order up another batch. If I figure you for one, that leaves five more (and a 2-3wk lead time).
    Anyone else interested? Should I have some more made?
    Up to you all...GTB
      Gt ! You Still Holding the one for me?
        GT:
        Thanks for quick feedback. In case there's not enough interest to order the minimum number of thru-hole boards, do you have any idea when the link to the HHd1 GIF file will be fixed, so I could at least make my own board? When I click on the link, the file won't download. Check it out below, from the HH project page.
        Through-hole PCB Layout (2x) (452K GIF, 600dpi) - Rev D
        As an alternate, I guess I could bite the bullet and tackle the SMT version.
        Thanks in advance for your answer.
          GT,
          I would purchase one of the boards.
            I'll Take One
            Hi GT,
            Put me down for one also.
            Thanks,
            Rip
              Originally posted by GT Blocker View Post
              Hey oldjet,
              Up to you all...GTB
              Hi, GTB:
              Since no one's responded to my inquiry regarding the dead link to the HHd1 GIF file, I'll assume making my own PC board is a dead issue, as well. In which case, could you please provide the cost of ordering the boards from you? If six individuals aren't interested, perhaps I could purchase enough to make up the difference, if it's not too cost prohibitive. Reckon I could assemble one as is, and experiment with the others.
              Many regards.
              P.S. Anyone remember Jetco?
                Hey oldjet,
                Up to you all...GTB
                Hi, GTB:
                Many regards.
                  Hello Oldjet and GT Blocker , as you know , very soon will be a "small" add-on circuit board for the Hammerhead , a USB programmable device/controller . After this programmable USB device is available , and I will say this very quietly , expect a big demand on the Hammerhead thru-hole "PCB" board's , If they become available again !!!! After the USB mini-board is released , I hope "someone" makes available some more Hammerhead Thru-holes . I hope both are available in ample quantities , at least for one last time !!!..........Regards....Eugene
                  Oldjet , Yes I remember Jetco from the 1970's , do you ??
                    Works fine for me... what happens when you try?
                      Thanks for the quick response, Carl.
                      I can open up the following Rev C GIF file just fine.
                      Through-hole PCB Layout (2x) (246K GIF, 600dpi) - Rev C
                      But when I click on the following Rev D GIF link, I get the blank frame shown below, with the red "X" in the upper left corner.
                      (By the way -- sorry about the double post above. I had to run an errand in the middle of the post, and when I submitted, I found the system had auto-logged me out. I logged back in and submitted again, without realizing the first submission had already been accepted).
                        Try right clicking on the link and saving it. Then open it with a photo viewer. I had the same problem and that worked fine.
                        Rip
                          That worked
                          Rip
                          "Save as" worked -- should have thought of that before. Thanks UWLocator.
                          I'm still interested in purchasing a board or two. GTB, can you keep us posted on the status?
                          Best regards.
                            Hello Oldjet , welcome to this Forum !! I have been on this Geotech Forum for almost 7 years now , almost everyday !! It is a Great place to be , and in the next several months , I think we will see some "great projects" get completed . When you post on a subject here on geotech always hit the preview post to check if your typing and or photo looks good , then hit submit reply . I am also interested in 3 or 4 Hammerhead PCB Boards , hopefully they will be available at the start of the new year. .........Take Care....Regards....Eugene
                              Hi, GTB:
                              Also works fine for me. No need to save ... just click.
