Hi All,
My first attempt to test my Hammerhead ended up with some smoke coming from the audio pot. That happened when I got with the setting close to the maximum volume. I was using a small power pot, and a 8 ohm speaker. I am not sure I didn't have some errors in circuit, but I think I didn't.
I put a resistor in series with it (few tens of ohms), to avoid increasing the current through the pot too much. This way it was working ok, but a lot of the audio signal was dissipated by the pot + resistor.
For this reason, I decided to use an audio transformer to increase the impedance of the speaker. I used a small transformer that I purchased from Jaycar: 1K OHM CENTRE TAPPED - 8 OHM OUTPUT TRANSFORMER
I still have plenty of sound at maximum volume. Before I had some sort of a harsh sound coming from the speaker at higher volume, now it's better.
At present, I am using a 1kOhm log pot for the speaker, I will change to the 5kOhm pot when I will get one.
Nicolae
Nicolae
