I want to ask several questions regarding the 74HC221 ICs, and the four multivibrators within those two chips. I've only seen one authoritative waveform plot of only TP6 and TP7, and and trying to determine if there are problems with the timings I am generating.
The one plot (mentioned above) was at the end of Carl's Hammerhead documentation, showing TP6 & TP7. Both are the same width. Can they be differing pulse widths?
I am seeing a wide pulse on TP6, and a narrow pulse on TP7 (about 5X longer, and leading TP7 in time) - and they overlap in time. That is not what Carl shows in his documentation.
Are there any clear application notes, or descriptions on how these multivibrators can use the same RC pair on IC12b, via the two diodes? I have been out of the loop with electronics for many years, and want to manually figure what timing pulses I should be seeing. I would feel much more comfortable in diagnosing this, with my own independent confirmation of waveform timings.
It may be even more hidden bad solder connections, due to the unexpected higher temps required for RoHS soldering today - which was NOT what I planned for. I've seen way too many of those in the last couple days! I've flipped the PCB over so many times, I am beginning to break connections (I have the main pots for panel mounting, on wires), etc - what a hassle! See this thread for what I'm talking about.
http://www.geotech1.com/forums/showthread.php?t=17311
