sampling
  • sampling
    Not sure if this is the correct location to post this but anyway.
    I've been looking at making a modified version of the HH, can I replace the 4066 switching circuit with a couple of LF398 sample and hold ic's then connected to the diff amp. Or will the circuit only work with sampling only 4066 ?
    I do realize that the timing circuit would need to be modified as the LF398 has a logic input of 0 to 5 volts.
    Sorry for the noob question.
    Mick
    Mick
    Hi Mick,
    At the post below, you can see a discriminating circuit that uses LF398 S&H amplifiers. This is "Open Source", you are free to use it.
    An induction-balanced PI design originated by Tinkerer and open for community development.
    Tinkerer
      Hi Mick,
      Tinkerer
      Hi Tinkerer, thanks for the reply, I'll check it out.
      Mick
