Replies to Minipulse Plus
  • Albdelafar
    Hi
    I have a question about settings on MPP rev-E.
    Is it normal that my speaker ring when my Audio (threshold) is set to 0V ?
    I tried to disconect the coil to avoid interference but is stil ringing i tried to replace the 8ohm speaker by a buzzer and it's ringing too.
    If i whant to stop the ring i need to down the treshold very low.
    I suppose this is not normal, can someone confirm ?
    Best
    Alban
  • Qiaozhi
    Originally posted by Polymer View Post
    Thanks Qiaozhi, I have been playing with the Crossbow version of the "static" mode you mentioned. It works quite well ...
    Am having a closer look at the original MPP circuit now. Is this the part that you mean with the swapped R 100k and C 47nF as compared to the MPP E 470nF & 1M?
    [ATTACH]46571[/ATTACH]
    Yes, that's correct. The original MiniPulse circuit does not provide a self-adjusting threshold, as the 100k resistor and 47nf capacitor form a low-pass filter, whereas the MPP uses a 1M resistor and 470nF capacitor as a high-pass. If the Crossbow's quasi-static mode works for you, then that's probably the best option. Reverting back to the original MiniPulse configuration (with the reduced gain) with not only lose depth, but will also require constant manual threshold adjustment.
  • Polymer
    I think your best option would be to use the same quasi-static mode as Crossbow.
    This circuit uses a 470nF capacitor (same as C9 in the MPP REV-E schematic) with 3 resistors in series going to 0V (in place of R6 1M).
    The 3 resistors are 2M2 (fixed), 1M (Auto-track external pot), and 100k (fixed). There is also a switch across the 2M2 resistor to change between Dynamic and Static modes.
    Or you could try option 2 as per the original Minipulse circuit, which can be seen here -> https://www.geotech1.com/forums/show...066#post183066
    Note that the feedback resistor of U4a is 4k7, so the gain of this stage in the original circuit is much lower.
  • Polymer
    061 may do it for SAT, but 061 in a previous stage is the one feeding the offset and 1/f noise. Picking an opamp with a low 1/f corner frequency for the circuits prior to SAT will improve things a lot. Bipolar opamps tend to have a significantly lower 1/f corner.
    Thanks Davor. I don't really understand what you are saying in practical terms. Isn't it the 062/072 op-amp that is feeding the integrator?
    Is right to understand it like this: the 1/f noise "fills" the integrator faster than say the leakage current, hence is more important to get rid of?
  • Qiaozhi
    I also tried an on/off switch in series with the 1M resistor like you mention.
    It works in a quasi static mode with constant reduction of detecting distance.
    Usable for around 15-30 seconds, too short for my pinpointing adventures.
    That is why I would like the first mentioned possibility to work.
  • Davor
  • Polymer
    Originally posted by Xtrem View Post
    Not so easy, offset problem in the next stage, (061) "zero" button is necessary
    [ATTACH]46466[/ATTACH]
    Thanks Xtrem. I do not want to install an extra pushbutton for this ... will be difficult.
    I might try toggling to a larger resistor when going in "static" mode. eg. 5-10MOhm.
    Or I might try what I believe Carl wrote "... important to have low input bias current ... " the opamp LMC6082AI has only 4pA, so might work for this.
    But am just getting into reading datasheets so it would be great to know if someone has already tried it or is this nonsense?
    I am not looking for constant static mode, but one that works at least for a few minutes without losing much depth.
  • Xtrem
  • Polymer
    To remove the SAT permanently and use non-motion, you can swap C15 (470nF) for a 100k resistor, and R29 (1M) for a 470nF cap. (See original MiniPulse schematic.)
    Or - you can probably simply add a switch in series with R29 to toggle between the two modes. I haven't checked this as a solution, so you'll have to try it.
    Hi George,
    I tried this with a double toggle switch. The static mode does not work, no audible signals at all.
    When switching back over to sat-mode the MPP works just fine again.
    What might be going on here?
    Here's my "translation" of the schematic for that into a wiring diagram. Maybe something is wrong!?
    Any ideas?
    How do I delete the attached picture below? "Attached Images" ...
  • Tibuck19
    I am just completing the minipulse but I hate the click click sound. It is no good for faster sweep speed on beach. It would be nice to see a more improved audio vco circuit for what is otherwise a very good design. Something along the lines of a small stand alone PCB mod for better vco audio.
    That was exactly I was thinking a VCO board for the audio.
  • dbanner
    And what about the vSAT/sweep speed relationship with click click bumblebee in your ears. Some people just want to get on with things and not spend hundreds of man hours experimenting with VCO mod, having to learn rocket science in the interim.
    If you want a good beach detector, why heck, just buy one.
  • kt315
    you can record your voice. MPP will say GOLD on gold and FERROUS on ferrous. improved? i think yes. https://www.ebay.com/itm/3-4-5V-6s-I...YuNr:rk:4:pf:0
  • dbanner
    Originally posted by Tibuck19 View Post
    Is there a way to get the MMP to sound more like the GPZ hum rather then the clicking ?
    So much work done to bring fine kit with build instructions etc., But same annoying click click Geiger counter rubbish.
  • Tibuck19
  • Goaty
    Already tried the 100R trimpot - you could be right about it not making much difference. Would a higher value make any difference and, if so, what would you recommend?
    Look at integrator out, TP4 with a scope. Hold ceramic or fridge magnet next to coil and pull away quickly. Try with pot adjusted each end, if pot is high enough resistance polarity at TP4 should change. Don't have a MPP but works with my detector.
    Thanks for that - I will give it a try as soon as possible.
