I tested the metal detector on my table. I used 15 cm normal wire (no coax) to connect the coil to the pcb.
By adjusting the potentiometer I got a nice constant sound, very very low freq - a single frequency, close to zero Hz.
Then I put the coil at the end of the stick (plastic) and used coax cable to connect the coil to the pcb. About 1.6m, 75ohm (3C-2V coax for TV).
Now the sound is not stable anymore. It fluctuates between low and high frequency.
How to get rid of this problem?
I WILL make the coax cable shorter but there is a minimum length I need (90cm).
Maybe I should also readjust the R6 trimmer with the coax cable installed.
