What is the purpose of the series diode?
  • Teleno
    do you mean the capacitance between GATE and SOURCE-DRAIN channel or SOURCE and DRAIN?
    Te capacitance between drain and source (Coss).
    It's in the order of nF at low voltages and is in parallel with the coil. See Coss in Fig. 5 of this datasheet https://www.vishay.com/docs/91070/sihf840.pdf
    I've explained it in this post https://www.geotech1.com/forums/show...576#post226576
  • kt315
  • Teleno
    your screens are different scaled... i see 80ns at first and 40ns on second. is there a problem to show in one scale?
    Yes, there is the problem that I'm experimenting with different coils and circuits and I can't revert hardware changes just to make one point.
    But it's the delay relative to the peak that's important, not the scale. The difference happens at any scale because the Schottky starts isolating the capacitance right at the peak, the PN-junction diodes don't.
  • kt315
  • Teleno
    capacitance of a cable to coil is 200+pF and capacitance of winding. no sense.
    MOSFET capacitance is 10 times that, so it makes lots of sense.
    This is the voltage at the drain when the MOSFET capacitance is isolated by a Schottky diode:
    Notice how the drain voltage starts decoupling from the coil voltage right at the peak, with no delay.
    Instead, a fast diode still has a considerable delay, as the drain and coil voltages remain coupled for a while after the peak, the decoupling starting much later.
    Fast recovery diode:
  • kt315
  • Teleno
    schottky has just one advantade - bit low direct voltage. but How Much low?
    on just 1...1.2V. i do not see any advantage to use a schottky in this case.
    The main advantage is zero reverse recovery time, as I explained.
    Regular diodes conduct when reverse polarized for up to 1us. Fast recovery diodes from 50ns to 300ns.
    The advantage in this case is a faster isolation of the MOSFET capacitance.
  • kt315
    Certainly, and there are schottkys with similar ratings too. For example GC2X8MPS12-247
    But I don't think the average detectorist here is designing electric cars.
  • Carl-NC
    Qiaozhi,
    If you plan on writing another book, article, or forum thread on Geotech1, please consider doing a trade off analysis between these variables.
    1. Coil inductance
    2. Resonant frequency
    3. Total capacitance as seen by the coil
    4. Coax cable effect on capacitance seen by coil
    5. Damping resistor value
    6. Effect of damping resistor value on the coil discharge slope relative to fully stimulating a variety of target TCs
    7. Delay necessary to detect a variety of low TC targets
    8. Total power being used to make the TX pulse
    9. Coil making techniques needed to work at low delays
    10. Now the main point: The trade offs between the above issues to optimize response from various target sizes, shapes, metal type and TC.
    If you did this you would synthesize a lot of Geotech1 forum content in one convenient place and help PI detector builders target their own detecting priorities.
    Forum members, do you agree?
    Joseph J. Rogowski
    Items 2, 3, 4, 5, and 9 boil down to the same issue: minimize capacitance. Otherwise, most of this was being discussed in a thread ironically named "Optimizing Target Responses." As I am motivated (and as people ask questions) I will continue that thread.
  • Qiaozhi
    Qiaozhi,
    1. Coil inductance
    Joseph J. Rogowski
    This would be a complex task, but probably best carried out in a SPICE simulator.
  • Teleno
    stth1210 has 80 and 120 A pulsed. reading the datasheet.
  • kt315
    If you read the datasheet it can withstand 10 A pulsed.
  • green
    The added diode allows earlier sampling. If pulsing 10A, don't need earlier sampling(don't want diode).
  • Teleno
    it's 1 A. we need 10+ A.
  • kt315
    Originally posted by sunita.pradhan View Post
    You may try - GB01SLT12-214 also 1.2KV,5p capacitance, less than 10ns , 10uA max leakage...only Power dissipation is 19W vs 64W.
