hola amigos del foro me podrian ayudar estoy tratando de aser una bobina doble d 38cm por 38 cm tengo la bobina orijinal como de vase gracias
Diy DD coil for MPP Beach Rev-E calibration?
Please read the forum rules -> Basic Rules of the ForumsOriginally posted by carloss View Posthola amigos del foro me podrian ayudar estoy tratando de aser una bobina doble d 38cm por 38 cm tengo la bobina orijinal como de vase gracias
and make your posts in English.Last edited by Qiaozhi; 06-11-2019, 04:10 PM.
if to protect my MPP I have built a second TX circuit for the coil.
I have used the same Mosfet and a fast diode DSEP15-12CR. This diode support 15A. Do protect a 10ohm resistance with 50W are in series.
The TX circuit work good. The switching signal I have taken from TP2, nothing get warm.
Unfortunately the RX-circuit doesn?t work if I use this setup.
On TP3 are the signal as on TP2. Very strange because the Fly back are about 300V and the curve from the coil looks good.
What did I overlook. The audio signal what I hear are completely constant. It doesn?t recognizes if a place a metal on the coil.
