Step 3- connect oscilloscope probe earth clip to tp5(0v) and bench power supply shoots up to 1.44a draw
This is a good reason to use an isolated PS or a current limited battery.
However, the scope measurements can be done with scope "ground" connected to the PS Negative (PS Ground). You can then clip scope probe to the Positive (tp5-0V) then adjust the scope's vertical to zero.
