What is the best frequency response for the preamp in a PI ?
If you want the beez kneez PI front end you can base it on a LM318, connect the dff amp inputs to V- and use a large junction bipolar transistors as a diff pair and connect to pin 1 and 8 comp pins tie together 2 ZTX 851 run 6 ma though each transistor and you will have a NF of just under 0.6 Db and 3 Db FQ point around 30 Mhz.
You accused me in an earlier post of simulating too much and not building real world circuitsOriginally posted by Detectorist#1 View PostHi moodz,
"where it matters ... the extra dollars for an AD797 only compensates for a less than optimal preamp design."
Show us what the optimal design of preamp with NE5534 should be and this design will eliminate using AD797.
In reality simulations are just "visual mathematics" and following the old proverb of "measure your wood twice before cutting once to build your house.
There is no optimal amplifier .. depends on many factors .. you must design not read catalogues. If you have deep pockets use the AD797.
There are two amplifiers in a PI the preamp ( prior ) to demodulation and the sample amplifier / integrator ( post ) demodulation.Originally posted by Detectorist#1 View PostHi moodz,
Process of sampling (demodulation) is non linear process, and on the output will be: f1,f2,nf1+/-mf2.
But we make filtering of these signals: we use 0-appr.5Hz for non motion mode and 0.1hz-appr.5Hz in motion mode. The 1/f noise appear in this band for unipolar Tx pulses. As Carl mentioned, 1/f noise absent only in bipolar Tx pulses.
SImply put the preamp is dealing with a signal or harmonic of the TX frequency that is modulated with target signals and other unwanted signals. The post amp is dealing with the demodulated signal as you state within say 0.1 to 5 hz ( personally I use 1 to 10 hertz ) .
So the post amp could use a chopper op amp ( which is why the 1/f disappears in the bipolar case also ).
A chopper amp is also more suited for the post amp than an expensive low noise amp. ( eg OPA2188 )
Hi moodz,
Hi moodz,
Its unlikely that a couple of nanovolts at 1KHz to 10Khz will dominate your other noise sources in a typical PI.
Originally posted by GeoMax View PostHello folks,
a question... I've been looking at the datasheets of all the opamps suggested here. Is it really worth paying about 20 euros for an AD797, for example, compared to about 1 euro for an NE5434? In my opinion, the performance under real conditions is not much better to make it worthwhile. Now the Analog Devices OpAmps are really very good. But from a commercial point of view they are also completely overpriced. A money-making machine for Analog Devices. For the price of an AD797 you can almost buy the components for about 2..3 complete hobby detector kits the size of a Hammer Head PI detector project. Is it really worth it to have an AD797 in the circuit?
What is your opinion?
winner !
For the preamp on the PI detector the useful signals are not in the same band.Originally posted by Detectorist#1 View PostHi pito,
Yes, the HF noise is very easy to be filtered with LP filter. But in PI technic the problem is that useful signals and LF noise are in the same band. In single polar mashines, only way is to use low noise OpAmps.
Referring back to the noise performance of an opamp below .. The wanted target signals might be from 10 Khz to 1Mhz ( depending on how fast your coil is )
... the USELESS signals are
DC error voltages @ DC
Earth Field Induced @ 0.1 - several Hz
Mains hum @ 50 / 60 Hz
When the target signal is demodulated at the output of the preamp these useless signals will be modulated by the demodulation ( sampling ) process and appear in the demodulation ( sampling ) output and due to non linearity of the demodulation ( sampling ) process will appear as intermodulation / convolution on the demodulated ( sampled ) target signals causing errors.
Most every RF designer knows this principle and it is the same in PI. ( its the physics of modulation / demod theory ). However it seems that not many RF designers also design PI circuits.
Hi kt315,
Slew rate of 22V/us for first Opamp is more than enough for fast regular PI projects, but the noise of Opamp is also important in high end projects for small targets. This is pointed from the practice.
Hi pito,
Hi GeoMax,
All depence of your final aim. If the parameters of HH PI are enough for you -no problem.
But if you want to reach top level of some prameter - you have to pay big money.
When I designed pinpointer for very small nugets (0.5grain), I trayed many OPAMPS with different slew rates and different noise figures. The best result give OPA1611 for 6.5USD. This is the reality!
Hi Carl,
It is very interesting for me what is the value of the change of the recovery time of 1N4148 with changing of the value of the clamp resistor from 1K to 5K?
Limitation of metal detector sensitivity/range
1. interference
2. noise
I use MCP6022, gain 100
1. amplifier output noise 2mv,
2. 25mV interference
What is the limiting factor in your case?
Noise can be easily filtered using an LP filter.
interference are more difficult to limit,
Instead, AD797 consider an active antenna design/Discrete components
Hello folks,
I have 10 LME49990 saving them for a special project, I have replaced the AD797
has SLEW RATE 22V/us, while obsolete LF357 has 50. we say about PI or VLF?
