This is my first time to build a vlf type detector.. can we get any sound from the speaker of the completed board without coil attached?? I finished one but i think it is not working , i cant heard any sound..
no sound..please help seniors and guru's..
Thanks WM6Originally posted by WM6 View PostFirst finish your detector, check your work a couple of time again before power on and then start alarm of non-working.
If you have audio battery check in your design, then voice should be heard at power on, even with coil disconnected.
now i know my board isn't working.
still not working... in all ic's excpt 4020 i got a + 8v in pin 8 and pin 7 in opamf..but in all pin 4 i only got.73 volt.. im using. Ne5534 in replace of lm308.. would it be the culprits? Or it have some other suspects?
