TGSL prints
  • CDI
    Yes, every elco above 16v is better. Sometime i put what i got, 63v, 100v. All works same.
  • ripsdevala
    Originally posted by CDI View Post
    Not factory made, but my personal work. Coil housing are directly from Bularia, u can find them on ebay, panel screen is also my creation mixed from several pictures from net, maked in adobe photoshop. I dont know for analog, if u have ac range in milivolt, why not.
    Let me buy one first ...
    Btw should I change all electrolict caps to 25v? So i can use 18v battery
  • ripsdevala
    I dont wish u to be disapointed, but, nulling and fixing the coil is much harder than soldering pcb components. Good luck.
  • CDI
    Originally posted by ripsdevala View Post
    Looks factory built to me, is your coil housing a home made? I try to make one and fail til now, no faccum work, just resin.
    Is there a way to nulling with analog multimeter
  • ripsdevala
  • CDI
    Its already fix CDI, yes thanks, i like the the one package file if not troublesome,
    Trying to nulling the first time.
  • CDI
    This is schematic with mpsa13 audio transistor.
    Also, this is my TGSL build:
  • ripsdevala
    If u dont have right schematic for 1265 version i can give u later, cant atm cause in not near my pc.
  • ripsdevala
    Haaa! Success, CDI was right, 2n2222 is reversed...
    now coiling....
  • CDI
  • ripsdevala
    My bad... wrong upload same folder, i mean this scheme
ID:	346205 not yet checking
    I follow all parts acording to pcb pic, not the schematic
    Pin 4 is 0.9 from two UA741(LM308 subtitute)
    ...I dont know what is charge pump
  • ivconic
    Oh mannnn!
    What the hell are you doing here?
    Look again page no 1 of this topic and post no 1 on that page.
    You have there zip file with all relevant files for this topic.
    You should NOT pay attention on other stuff posted somewhere else.
    You asked for that project and i gave you that project. Obey it.
    Otherwise don't ask questions which are not directly related to this particular project.
    And wtf are those voltages?!
    Can't you measure voltages ONLY on pins.4 on all DIL8 opamps that you used there?
    So ONLY pin. 4 (minus voltage).
    Take voltmeter; black probe attach to battery minus pole and red probe to pin 4. on opamps, one by one opamp.
    And check what voltage you are having there.
    If that voltage is not in range -6 to -6.22V than charge pump is not working.
  • ripsdevala
    Check voltages at opamps.
    Especially check if you have "-5v" (actually should be -6.22V) on minus pins (pin 4.) at opamps.
    Ivconic sir, for now pin
    1. 0.9v
    2. 2.3
    3. 0
    4. 0.9
    5. 0
    6. 8
    7. 2.6
    8. 0.9
    Using 4xAAA = 11.3v remaining
    ...your transistors near voltage regulator looks like wrong orientated, or only one. Check pinout, collector from both transistor must be connected togheter, check schematic again.
    Same thing with TX stage transistors.
    From what i see in this picture, FET's are good orientated. Also, check pinout for mpsa13 in audio stage.
    Yes CDI, from the schematic its wrong
    Because this schematic
    Have some different with the pcb
    Let me change 2n2222 like the schematic.
    For MPSA13 im sure its on the right direction according to pcb layout and emiter from schematic.
  • CDI
  • ivconic
    Already do that, nothing happens with 12v power bank, let me try using battery's, i dont know if this can use 18v, but all my electrolict caps is 16v
    I see... that's why I burn twice my barracuda with laptop adaptor and CPU power supply.
