Hi all!
i started building TGSL edu this winter but then got busy with studies and havent done much since. im now starting where i left off, having soldered the entire board and made a coil but it does not function properly. im trying to do nulling and taking some measurements with oscilloscope but it looks kind of strange?
im measuring at these points:
heres my tx signal:
and heres U101a, pin 7:
its a really weak signal (could be correct) but it has those spikes that reach twice as high voltage as the rest of the signal. any idea what is causing that?
when i measure directly at rx:
it has similar spikes and its also a relativly weak signal, but maybe this is as it should be.
now to the issues, when i was trying to null the coil (by making a difference of 20 degrees between tx and U101a, pin 7) they were following each other, so i can adjust it a bit but it stays around 60 degrees if i remember correctly (forgot to take an image of it). how is it that they are following each other? and do the other images look correct?
i get a few beeps from the detector when im touching the cables to the switch and pots, but it does not really react when i move metals over the coil. guessing this is because i dont yet have it in a grounded case, just got the card on its own.
HTML Code:
http://www.geotech1.com/forums/attachment.php?attachmentid=31353&d=1412208437
