Help identify value of Capacitors
  • chuubaba
    Here is what i built till now of TGSL. This is the 2nd time i am building this as my first attempt was a disaster. Now i realize that the two 220 caps are polarized as used on top middle of the board. I hope this is correct
  • rickb
    The 0.22(220nf) are regular polystyrene caps.
    Probably polyester.
  • dbanner
    Above I mistakenly said I have never seen 220nf ceramic disc, what I meant was I have never seen 220uF ceramic disc caps.
    They would be very, very large.
  • dbanner
    A good components/parts list should specify the type that is required for each component.
  • dbanner
    When it comes to capacitors, they are application specific, that is to say the different types are so designed to give them special purpose applications, depending on what is required.
    Electrolytic, tantalum, ceramic, polystyrene,etc,etc. All have unique characteristics.
    So you should be careful which type of cap the schematic recommend.
  • dbanner
    As you should know, especially if you intend to construct your own projects, how to identify components types etc., And how to read schematic diagrams. Just the basics.
    Polarized caps, as the name implies, have a positive and a negative end.
  • dbanner
    Have a look at the schematic. It has two 10uF electrolytic caps connected with the negative terminals back to back, giving the required 4.7uF n.p(non polarized)
  • chuubaba
    How to meet this requirement. Next i can see two 220nf polarized caps and I only got these in ceramic with capacitance code as 224
    Originally posted by rickb View Post
    Low value caps are generally polystyrene or ceramic and are non polar.
  • rickb
  • chuubaba
    So I should take two polarized 10uf capacitors and join their negative terminals with each other and this will do the job Right ?? I have two 10uf 25V polarized capacitors
    In the original schematic, it is non-polarized capacitor. Since these types of capacitors are more difficult to find laying around, you can substitute by placing two polarized electrolytic caps in series with the two negative terminals connected, as shown on layout. Just remember that the same value can be obtained by using two same value caps divided by two. So two 10uf caps connected this way would be equal to 5uF
  • kt315
    Originally posted by chuubaba View Post
    kt315 thank you for your attention. Please specify the value of the capacitor highlighted in yellow sandwiched between 4k7 and 470k resistors. Is this 15nf or 22nf ??
    15nF on input of RX preamp. 22nF in feedback. look on the schematic.
  • dbanner
    [ATTACH]43441[/ATTACH] Also the value of these two capacitor highlighted in Blue is written as 10 but the BOM only has one 10pf capacitor and even then how am i going to find polarity of it
  • chuubaba
    15nF. 22nF.
  • chuubaba
Name:	TGSL PLACEMENT.JPG
ID:	351582 Also the value of these two capacitor highlighted in Blue is written as 10 but the BOM only has one 10pf capacitor and even then how am i going to find polarity of it
  • kt315
    15nF. 22nF.
