Hi, a few weeks ago I finished my TGSL.
The problem is this: the first time I turned it on, it didn't make a sound. I noticed that when I removed the LM308 (U105), the detector was working but no more than 5 cm.
Then I changed the LM308N (these were also heated) for some NE5534.
Now the problem is that it continues to sound, when an object passes, it stops sounding. But it sounds again, that is, it works the other way around.
The Tx coil measures 6mH and Rx 6.5mH. I have measured the frequency of Tx with my multimeter and it gives me 14.5kHz perfectly. I changed Tx to Rx and I get about 13.9kHz according to the manual [When I measure Rx it gives me 200-300Hz below the Tx frequency (14.5kHz)].
The minimum I achieved on pin 7 of the LF353 was 200mV, it's high, but I don't know how to lower this. I have read that pin 7 of the LM393 (U102b) should be close to 0, but it gives me -2.5v.
I checked the voltages on all the integrated circuits (approximately -6v and 8v).
I checked all connections.
I have LM358P, I'm not sure if this last letter can be a problem, since I read that the LM308 works but LM308N does not.
I have the JFET BF245A, some say it works just like the BF245C, but in the Russian forums I read that it does not.
I have measured the current and I have about 80 mA while it sounds. If I remove the U105, the beep stops, the current drops 50 mA and only detects less than 5 cm.
Also, the L7808CV warms up, and I don't think I should, as it is 1.5A.
Can I measure Tx amplitude directly with the multimeter? I should be at 16v, but with the multimeter I get 15mV.
I don't know what to do anymore
I guess it's an IC thing, but I don't know which one. Are there voltages I can compare?
