Hello.
I have a Tgls detector, to which I want to attach a VDI. I followed a thread about this and thanks to Prospecteur and Virdi_248, who did an amazing thing in this regard, I decided to attach a VDI with Arduino to my Tgsl.
My problem is that when compiling the code I have an error and I can't finish it. Error is;
(MD_V13:211: error: 'class LiquidCrystal_I2C' has no member named 'setBacklightPin'; did you mean 'setBacklight'?
lcd.setBacklightPin(BACKLIGHT_PIN, POSITIVE);
setBacklight
MD_V13:211: error: 'POSITIVE' was not declared in this scope
no matching function for call to 'LiquidCrystal_I2C::LiquidCrystal_I2C(int, int, int, int, int, int, int, int)'
I'm using lcd 1602+ i2c. I've changed the liquidcrystal_i2c library several times, but the problem persists. I don't really know what to do. I'd really like to have this project completed with your help, thank you.
August 2014 by DarenT
Work based on earlier work found on Geotech forum and others.
#include <EEPROM.h>
#include <Wire.h>
//use #include <LiquidCrystal.h> if you don't have I2C LCD
#include <LiquidCrystal_I2C.h>
#include <MenuSystem.h>
#include "defs.h"
#include "VdiLcd.h"
#include "params.h"
#include "menu.h"
#include "encoder.h"
//use "LiquidCrystal" if you don't have I2C
LiquidCrystal_I2C lcd(I2C_ADDR,En_pin,Rw_pin,Rs_pin,D4_pin,D5_pin,D6 _pin,D7_pin);
CVDILcd vdi(&lcd);
CParameters params;
extern MenuSystem ms;
//signal processing
bool generateReading(int* pPhase, int* pStrength, unsigned char* signalValues, bool* pbadReading)
#define SAMPLE_BUFFER_SIZE 350
unsigned char strenth[SAMPLE_BUFFER_SIZE] = {0,};
unsigned char angle[SAMPLE_BUFFER_SIZE] = {0,};
int index = 0;
bool enoughSamples = false;
unsigned long startTime = millis();
bool needToClearLastResult = true;
bool retValue = true;
while(1)
//digitalWrite(8, LOW); //debug
//delayMicroseconds(100);//debug
//digitalWrite(8, HIGH); //debug
//check the encoder and break out of the processing on user button press
if(checkEncoder())
params.m_showVDI = false;
retValue = false;
break;
//sample signals
float X = 0.0F;
float R = 0.0F;
const int SAMPLING_LOOP = params.m_readingSamples;
for(int n(0);n<SAMPLING_LOOP;n++)
X += analogRead(XPin);
R += analogRead(RPin);
X /= SAMPLING_LOOP;
R /= SAMPLING_LOOP;
//Serial.print("------------------------------------------\r\n");
//Serial.print(X - params.m_XBias);
//Serial.print(",");
//Serial.print(R - params.m_RBias);
//Serial.print("\r\n");
//delay(5);
//continue;
//if opamp is saturated; break and report it
if(X >= params.m_maxSignal || R >= params.m_maxSignal)
*pbadReading = true;
break;
//bring to "virtual ADC zero"
X = X - params.m_XBias;
R = R - params.m_RBias;
//screen out samples using signal R polarity as set in params
// 0 - use any polarity
//-1 - use only negative R
// 1 - use only positive R
if( (params.m_sigPolarity<0 && R>0) || (params.m_sigPolarity>0 && R<0) )
X = 0.0F;
R = 0.0F;
//phase in degrees
int phase = ( (X == 0.0F && R == 0.0F) ? 0 : atan2(X, R) * 57.295F );
if(phase < -90)
phase = -90;
else if(phase > 90)
phase = 90;
angle[index] = phase + 90;
strenth[index] = int(sqrt(X*X+R*R));
index++;
//ring buffer; wrap around
if(index >= SAMPLE_BUFFER_SIZE)
enoughSamples = true;
index = 0;
if(!enoughSamples)
continue;
//find peak signal
unsigned char maxVal = 0;
int maxIndex = -1;
for(int n(0); n<SAMPLE_BUFFER_SIZE; n++)
if(strenth[n] > maxVal)
maxVal = strenth[n];
maxIndex = n;
//is the peak strong enough
if(maxVal < params.m_minSignal)
//no strong signal is present; its a good time to clear LCD if needed
if(needToClearLastResult && (millis() - startTime) > 5000)
unsigned char empty[40]={0};
vdi.updateVDI(params.m_vdiStyle, 0, 0, empty, false);
needToClearLastResult = false;
continue;
//where in the buffer is the peak
int dist = index - maxIndex;
if(dist < 0)
dist = SAMPLE_BUFFER_SIZE + dist;
//check if the peak is in the middle of the buffer
if(dist != SAMPLE_BUFFER_SIZE/2)
continue;
//we have strong enough peak in the middle of sampling buffer
//calculate the result and break the loop
float angleAvg = 0.0F;
float strengthAvg = 0.0F;
int avgSamples = 0;
const int reach = 1;
int n = maxIndex - reach;
while(avgSamples < (reach*2 + 1))
if(n<0)
n += SAMPLE_BUFFER_SIZE;
else if(n>=SAMPLE_BUFFER_SIZE)
n %= SAMPLE_BUFFER_SIZE;
angleAvg += (int(angle[n]) - 90);
strengthAvg += strenth[n];
avgSamples++;
n++;
*pPhase = angleAvg/avgSamples;
*pStrength = strengthAvg/avgSamples;
//sound handling
if(params.m_soundOn)
tone(SND_PIN, *pPhase <= 0 ? SND_LOW_TONE : SND_HIGH_TONE, SND_LENGTH);
//prepare data for the 40x8 graph
int i = 0;
int k = index;
const int inc = SAMPLE_BUFFER_SIZE/40;
while(i<40)
if(k>=SAMPLE_BUFFER_SIZE)
k -= SAMPLE_BUFFER_SIZE;
signalValues[i] = float(strenth[k])/float(maxVal) * 8;
k+=inc;
i++;
//measurement completed; break the loop
break;
return retValue;
// Standard arduino functions
void setup()
//restore from EEPROM
params.loadParams();
//LCD init
lcd.begin(16,2);
lcd.setBacklight(params.m_LcdBacklight ? LED_ON : LED_OFF);
//create menu
createVDIMenu();
//Encoder setup
pinMode(PIN_ENC1, INPUT);
pinMode(PIN_ENC2, INPUT);
pinMode(PIN_EBTN, INPUT);
pinMode(PIN_LED1, OUTPUT);
digitalWrite(PIN_ENC1, HIGH);
digitalWrite(PIN_ENC2, HIGH);
digitalWrite(PIN_EBTN, HIGH);
attachInterrupt(0, intrEncChange1, CHANGE);
attachInterrupt(1, intrEncChange2, CHANGE);
checkEncoder();
//initialize LCD GUI
lcd.clear();
lcd.home();
lcd.setCursor(0,0);
lcd.print("VDI v0.3");
delay(1000);
unsigned char signalValues[40]={0};
params.m_showVDI = true;
vdi.reset();
vdi.updateVDI(params.m_vdiStyle, 0, 0, signalValues, false);
tone(SND_PIN, 700, 200);
delay(200);
//Serial.begin(115200);
void loop()
if(params.m_showVDI)
int phase(0.0F);
int strength(0);
bool badReading(false);
if(generateReading(&phase, &strength, signalValues, &badReading))
vdi.updateVDI(params.m_vdiStyle, phase, strength, signalValues, badReading);
else
encoderHandler();
setBacklight
#include <EEPROM.h>
#include <Wire.h>
#include "defs.h"
#include "VdiLcd.h"
#include "params.h"
#include "menu.h"
CVDILcd vdi(&lcd);
CParameters params;
//signal processing
int index = 0;
while(1)
if(checkEncoder())
retValue = false;
break;
//sample signals
float X = 0.0F;
float R = 0.0F;
X /= SAMPLING_LOOP;
R /= SAMPLING_LOOP;
//delay(5);
//continue;
break;
X = 0.0F;
R = 0.0F;
//phase in degrees
if(phase < -90)
phase = -90;
else if(phase > 90)
phase = 90;
index++;
index = 0;
if(!enoughSamples)
continue;
//find peak signal
int maxIndex = -1;
maxIndex = n;
continue;
if(dist < 0)
continue;
int avgSamples = 0;
if(n<0)
avgSamples++;
n++;
//sound handling
int i = 0;
int k = index;
while(i<40)
k+=inc;
i++;
break;
return retValue;
void setup()
//LCD init
lcd.begin(16,2);
//create menu
createVDIMenu();
//Encoder setup
checkEncoder();
lcd.clear();
lcd.home();
lcd.setCursor(0,0);
delay(1000);
vdi.reset();
delay(200);
void loop()
int phase(0.0F);
int strength(0);
else
encoderHandler();
