Originally posted by soverey
Do you have RX coil leads reversed? (makes double-beep with target if you do).
Do you have DISC pot leads reversed? (will work backwards, but OK).
Have you mounted and fixed your coils, or are they still loose for testing?
What are you using for coil cable? Sometimes certain cables very touchy, cause beeps easily, or connectors are noisy.
Which exact circuit did you build (there are several versions)?
Does your sensitivity pot affect the beeping?
Is the beeping the same with headphones and speaker?
Is the speaker or headphones far enough away from circuit board?
Do you have power lines nearby or other strong EMI sources nearby?
-SB
