After setting up and glueing the home built dd coil for the tgsl as described, i was really pleased with the results and found it to be very sensitive on small coin sized objects ie. old english halfpenny at 36cm clear clean signal with discrim at rejecting most iron! but i then discovered that it also picked up my hand waved across the coil up to 12cm's away! i once had a troy x5 and found this done a similar thing when maxed out, so my question is do i go ahead with the full epoxy and seal the coil or will i have problems ground balancing etc with this? cheers andrew....
Have i made a very sensitive coil or do i have a problem?
Hiya, Andrew,... I've just wound/bound/glued my IGSL coils,... not had chance to test them, yet,... you have connected the shield/screening up, have'nt you??? sounds like a screen error,... ( I have just had 2 Mylar space blankets arrive from China,... will be sheilding my coils with it soon.....)
On a plus note, I would my coils as per the TGSL 101 info from Silverdog's website,.. 98 turns, and 107 turns come in at 6.02, and 6.47 millyhenries,... so, if they screen ok, I will be trying to balance/null them out soon,
Cheers, Good luck, Fred
hi fred! just knocked up a stem and tried it in the forecourt downstairs and it seams to behavingOriginally posted by Comp View PostHiya, Andrew,... I've just wound/bound/glued my IGSL coils,... not had chance to test them, yet,... you have connected the shield/screening up, have'nt you??? sounds like a screen error,... ( I have just had 2 Mylar space blankets arrive from China,... will be sheilding my coils with it soon.....)
i used alley tape for faraday sheild on the coils! sounds like yours is coming along nicely i recon your's will give the
boys a bit of competition up there! cheers andrew..
Yep, I bought 2 of these from Hong Kong, they are very conductive, and dont seem to suffer from cracking/breaking the silver,...... They did take 6 weeks to arrive, though!!!!Originally posted by 6666 View PostOopps told a lie, the were $1.60 and they are in the mail
now just got to wait for the slow boat from China.
Cheers, Fred
Originally posted by Comp View PostYep, I bought 2 of these from Hong Kong, they are very conductive, and dont seem to suffer from cracking/breaking the silver,...... They did take 6 weeks to arrive, though!!!!
Cheers, Fred
Ok, I take the above back,......
I have found that the above sheets DO crack, and cause open circuits on the shield,.... so back to the drawing board/Aluminium foil!!!!!!
Cheers, Fred
You might try looking at USB3.0 (maybe also USB2.0/firewire) cables and using their mylar insulation. Just strip off the plastic cover and each data pair is wrapped with aluminized mylar. Unwrap it from the pairs and use it on your coil.Originally posted by Comp View PostOk, I take the above back,......
Cheers, Fred
Barry
