PICS OF MY TGSL LOW RESOLUTION
If the coil has a 5-pin plug, then the answer is yes. The Tesoro coils with 4-pin plug have different inductances.Originally posted by daverave View Postcan i use a coil ment for a tesoro bandido micro max with this TGSL detector ????
I think the uMax uses a 5-pin plug, so it should work just fine with the TGSL. The actual TX frequency is not important for these coils.
Originally posted by Qiaozhi View PostIf the coil has a 5-pin plug, then the answer is yes. The Tesoro coils with 4-pin plug have different inductances.
ok , thanks Qiaozhi it is good to know
Qiaozhi is correct , I used the web coil and the solid which were 5 pin types the inductances were slightly different between the two but you can alter your CX capacitors to suit.
The golden rule with the TGSL coil is the .5MH between the TX and RX , for instance 5.9/6.4MH is a typical manufacture inductance value for the Tesoro coil or as we have made on here 6/6.5MH.
if you stray from those inductances you can play with CX to compensate but nulling and end results are disaponting.
Will put my hands up on this one I went through dozens of coils in the early days till getting it right in the end I bought manufactures coil to copy.
