I looked at the diagram again and zoomed out to see the eight 2k7’s to the right with “damping resistor determined by coil 250 ohm to 600 ohm”. I might try a larger value
Super BFO
Here is a very short test video of Super BFO1.
Its scorching in the Aussie sun today, but tested some Aussie coins, USA coins, steel bottle caps
you can tell the difference with a steel bottle cap.
That sound quite different to the one I made, the "idle" tone of mine is a much lower frequency and is a constant stable tone until a target is detected. I tried variations in the damping resistance but all I got was a loss in depth and sensitivity, although the idle tone changed. I think my coil has too much capacitance, I’ll try an unshielded coil with lower capacitance as a quick experiment. Although I’m getting a bit frustrated with this design – for the component count I expected more, and until I learn to program I think this is a dead end for me.
Today I tried a super sized coil its 17"x9" rectangle with round ends, I wound this coil for a pi project, but put more turns on it to measure 540uH, so I could try it on this machine first, the super bfo seems to like it, much better in air depth test.
Ground pin
see attached - is the ground, the terminal next to - is also ground .
(Ground is in blue, in the image attached)Attached Files
