Originally posted by Midas
At the time I used the Log amp, I found that the immediate advantage was for detecting short TC targets. For example, a 5us target signal, has lost about 85% of it's amplitude at 10us after switch OFF.
This is where the Log amp brings the advantage, towards the end of the decay curve. I found that I could still detect a 5us target after a delay of 20us, when using the soft clipping combined with the Log function of my simple circuit from post #455.
About IB-PI: this does not automatically mean that one can sample a target at any time. For the time being the "anytime sampling" only applies to the TINKERERS_TEM_IB-PI.
Even with the best balanced coil, there is always some residual TX decay signal. If we amplify this residual signal a 1000 times like it is usual with a Traditional PI, the pre-amp gets saturated. It will take some time to come out of saturation. Clipping helps some, but also distorts the signal.
Some Traditional PI designs use gating to cut out the Flyback. The problem with that, is that gating a several hundred volt signal adds a considerable amount of distortion and switching noise, as well as some time for the gated signal to settle.
In the TINKERERS_TEM_IB-PI design I use a radically different approach, that makes it possible to sample the RX signal at any and all times. It turned out that there is sooooo much more information available that way.
Tinkerer
