complete project
  • mschmahl
    Updated Schematic in PDF and for Designspark
  • Tinkerer
    Originally posted by sido View Post
    Hi Tinkerer, thanks for posting the link to Diptrace EDS.
    As a matter of interest and sorry to all being off topic, I read a post of your's from early 2011 and i gathered that you may have been using Diptrace and now changed over to Designspark. Correct?? and if so why??
    I have downloaded Diptrace and trying to learn it.
    Cheers Sid
    I downloaded Diptrace, but never got to really use it. When DESIGNSPARK appeared, I looked at it and found that it is the first full size, no restrictions EDS, with 3D, SPICE simulation and a parts inventory of 85,000 parts in 2D and 3D, totally free with no strings attached and no limitations. Regular free updates, tutorials, support and more.
    You also get a BOM that is linked to a parts catalog of a worldwide distributor and Datasheets.
    It is just too good to be passed by. Now that I am getting used to it I don't think I will ever change.
    Tinkerer
  • Tinkerer
    Thanks mschmahl for posting the updates.
    Some diodes in the RX circuit have a prefix 2Nxxxx. what should they be?
    Cheers Sid
    Thanks for the feedback. As you see on this schematic, it is a work in progress. The audio with the 4046 worked, but I was trying to improve on it. This is why we have another audio, using a 555 floating on the page. For the 2 diodes in question I used yellow LED's with a forward voltage drop of about 2.4V.
    It is extremely expensive for me to buy parts here, so I use what is available in the parts box. Not always the most appropriate.
    All the best
    Tinkerer
  • Tinkerer
    Originally posted by mschmahl View Post
    @ tinkerer
    Thank´s for the explanation. Do i have to change R4 and R39 on RX also?
    @Sido
    I have made some PDF´s to the changes.
    Yes, R4 and R39 on the RX board should be the same.
  • sido
    Cheers Sid
  • mschmahl
    @ tinkerer
    @Sido
  • sido
    I have little time at present. My 240 GB storage hard disk crashed and I am packing up my lab for moving. So you will have to exercise patience.
    http://www.designspark.com/page/desi...-pcb-home-page
    Here you can download the totally free DESIGNSPARK software. Full size, no restrictions.
    Tutorials:
    http://data.designspark.info/uploads...s_20130211.zip
    All the best
    Tinkerer
    Cheers Sid
  • Tinkerer
    Hi Tinkerer, any chance of posting the updated circuit changes in PDF that have been discussed in the last few posts. I dont have the EDS you guys are referring too.
    Once the Moodz UNIPI physical usable PCB and hopefully ideal circuit layout is produced, i want to experiment with your unique designs.
    Having wanting to do so for a while.
    Thankyou in advance.
    Cheers Sid
    Tutorials:
    All the best
    Tinkerer
  • sido
    Cheers Sid
  • Tinkerer
    Ah, like always I forget something.
    You can change R8 and R16 on the TX&PSU board to 1.5K to increase the pulse voltage range.
