I'm almost finished with the most common and interesting coil types. The question is, whether I should take the loser figure-8 coil into account. But this figure-8 coil is causing a lot of work for nothing.
I have analysed the following 10 inch coils so far:
- Mono coil (reference)
- Mono + stacked AI coil (The Eric Foster's coil in this thread - see the coil picture in the earlier post)
- Ground loop (GL) coil (TX, RX separate, RX smaller)
- Ground loop (GL) + stacked AI coil
- Co-axial stacked AI IB coil
- Concentric co-planar IB coil
- Tophat AI IB coil
- DD IB coil
AI is referring to the anti-interference (AI) feature (RX+, RX- connected anti-phase in series).
IB is referring to the induction balance (IB) feature.
If IB is not mentioned, it's a plain pulse induction (PI) coil.
Well, I'm thinking of adding a few configurations as well (Davor-Sergey at least. BTW!, I have found a configuration, which doesn't require a compensation (CX) coil).
BTW, I can also answer the following question regarding the concentric co-planar IB coil:
What is better: Smaller RX/BX or larger RX/BX in regards to SNR?
One interesting thing could be measured however:
The AI EMI rejection ratio for different co-axial distances. So we know the gain margin for compensation of the target response losses (the break-even point) and the remaining gain to get into the beneficial region.
I think, I'll make new measurements with an ultra low-noise amplifier to figure out the rejection ratios.
Oh yes, a lot of calculated data needs to be imported into an excel table, which is also causing a lot of work.
Be patient please.
Well, I have almost two days before the doomsday! I should really hurry up now!
Cheers,
