Has there been any discussion re use of copper clad aluminum wire for coil construction? I note that it is excellent for HF applications, but not so good for DC.
Copper clad aluminum wire.
CCA Used for HF Applications
One of the main traditional applications of CCA is in communication cables as the central conductor of coaxial cables. CCA is also sometimes used in enameled magnet wire when low weight is critical (e.g. coils for headphones and aircraft instruments). Due to the skin effect, which means that high frequency signals are mainly transmitted in the surface layers of a conductor, CCA is usually used for carrying high frequency signals. For these applications (e.g. coaxial cable) the higher DC resistance of the aluminum core is not so important. Indeed, in really high capacity, very high frequency coaxial cables signal transmission within the central core of the conductor is so negligible that hollow copper tubes, not solid wires, may be used.
Any thoughts on that?
