I know this is not a normal symptom.
On a DD coil the area from the front tip down 3" is dead to low conductors. In other words I can air test 3 different pieces of gold and the machine fails to respond (even less than 1/2” from coil) until the targets are more than 3" under the coil. No other coil I have does this and I'm sure it is not the norm.
Would this be caused by improper winding patterns in the front of the coil?
High conductors are not affected or I might say it is not as noticeable.
Other coils are not showing this problem on the same machine so the machine is fine.
