I understand binaural (crossfeed) and understand that you are a fan of it, but I fail to see the direct benefit using it in a traditional MD setup, which in a sense generates an mono signal.
Where this effect could be useful, is in a detector that uses the multiple search coil approach. But even there you would want true "stereo", and may use a bit of crossfeed for some comfort.(Releiving extreme stereo separation) By having multiple detection points, this would allow you to identify which side each target was on.
Let's say you had a silver coin 5" to the left of a nail. Now you take a swing from left to right. The first thing you would hear is the silver in the right speaker. As your swing progresses the silver can be heard in both left and right speakers as well as the iron entering the right hand speaker, then the last thing you would hear is the iron in the left as the coil leaves the target area.
The brief moment when the coils are over both targets, or targets that are closer together, you would hear the multiple frequency, simultaneous tones. Chords.
I suggest using something like one octave of a Hepatonic scale, which has 7 pitches per octave. (C)D-E-F-G-A-B-C Of course the actual notes could be customized for user preference.
Try it out here http://www.bgfl.org/custom/resources...2/music/piano/ Press the button on the left for "Chord mode". Select D and C1 which would represent iron and a high conductor like silver.
Press play chord. This is the signal I want to hear on a complex target that has both materials present.
Now lets add a gold ring to the mix, now select "F" and press play chord. It's still easily apparent that I have three distinct materials present in this complex target.
Even adding a fourth note works. After that point it gets harder to tell, but quite frankly if you have that many targets present you need to dig them up so you can separate them better.
Now this type of discrimination would be useful with or without the Left/Right location abilities I discussed early on.
